I am using the nRF9160 aws_iot sample. I was now trying somethings that are not optimal situations.
For example, I made some FIFO buffer to write in measurements in one...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
"I have now solved the process of writing NDEF messages to NFC via a smartphone, then sending them to a computer via serial communication. Now, I want to reverse the process...
I am working on a project that requires my MCU to have a sleep and awake cycle. I have noticed that when my MCU sleeps (by using k_sleep() in threads) the UART peripheral...
NB: I'm not using the full SDK, only the devicetree extension. therefore I must provide the path to zephyr base.
app.code-workspace
This works:
Unfortunately, this is...
I have got accel data from adaxl345 in nrf9160. I want to get vibration frequency (HZ) from accel data set using fft algorithm.
process:
1. collect 100 accel data every...
Hi guys:
Right now I have my custom board using nRF52833.
I wang to use DFU over uart to upgrade firmware.
I try a different way to enter DFU mode, and this require...
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
Hello everyone,
I'm encountering an issue with my Zigbee network that I hope someone can assist me with. Despite my efforts, I haven't been able to find a resolution.
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
Dear Support team,
I'm involved in the activity to migrate to NCS a project already developed & successfuly tested with using nRF52 SDK v17.1.0, over the custom board initially...
I'm encountering persistent address conflict issues within my Nordic project.
Occasionally, when a device joins the network, I observe address conflict errors....
Hello, I'm trying to use MCUBOOT with external flash on a nRF52840 board that has 4MB SPI flash. I'm using nRF Connect SDK v2.6.0. I've verified that the SPI flash works fine...
I used nrf52840 board with SDK 17_1_0
I used segger embedded studio IDE
I am not able to understand how i Implement VL53L5CX TOF sensor with nrf52840
so if any reference...
Hello!
i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
