I am using the nRF9160 aws_iot sample. I was now trying somethings that are not optimal situations.
For example, I made some FIFO buffer to write in measurements in one...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
I am working on a project that requires my MCU to have a sleep and awake cycle. I have noticed that when my MCU sleeps (by using k_sleep() in threads) the UART peripheral...
I have got accel data from adaxl345 in nrf9160. I want to get vibration frequency (HZ) from accel data set using fft algorithm.
process:
1. collect 100 accel data every...
안녕하세요. 스마트폰 앱에서 이전에 수집한 mac 주소에 ble 광고 없이 연결하여 수집한 mac 주소에 연결할 수 있는 설정이 있나요?
1. ble를 광고와 연결
2. 연결된 ble의 mac 주소를 스마트폰 앱에 저장하세요.
3. 다음 연결에서 광고 없이 수집된 MAC 주소(또는 광고하지만 숨겨진...
We had some trouble doing the certification of Tepec, Telec certification requires the RF power accuracy of ±3.8dB , while it is ±4dB in spec。Do you have any good advice
I am having problems connecting to LTE and AWS.
We had consultants developing the prototype code, and it worked perfectly on our 3 first hardware revisions (custom product...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
Am Implementing Zigbee on NRF52840 chip with help of VS Code.
Zigbee Stack : 2.5.2
I configured nrf52840 DK as Zigbee network coordinator and another custom made...
"I have now solved the process of writing NDEF messages to NFC via a smartphone, then sending them to a computer via serial communication. Now, I want to reverse the process...
NB: I'm not using the full SDK, only the devicetree extension. therefore I must provide the path to zephyr base.
app.code-workspace
This works:
Unfortunately, this is...
Hi guys:
Right now I have my custom board using nRF52833.
I wang to use DFU over uart to upgrade firmware.
I try a different way to enter DFU mode, and this require...
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
Hello everyone,
I'm encountering an issue with my Zigbee network that I hope someone can assist me with. Despite my efforts, I haven't been able to find a resolution.
Dear Support team,
I'm involved in the activity to migrate to NCS a project already developed & successfuly tested with using nRF52 SDK v17.1.0, over the custom board initially...
