Hi there,
I'm using an nRF52840 pin to monitor GPIO state transitions, but it keeps reporting frequent phantom low transitions without high transitions in between. According...
i just bought 4 nrf21540db's that I would like to use with Shockburst. My understanding is that the modes, etc are setup through gpio pins, but the power settings are done...
On a nrf52840 (sdk 16.0.0) I have sporadically an unexpected behaviour when I unprovision my device, both with the nRF Mesh and with our custom app. As showed in...
I trying to generate dfu images following the procedure described below:
https://novelbits.io/nrf52-ota-dfu-ble-part-4/
the procedure to generate files is ok,...
Hello to everyone,
I'm pretty in new in developing with Nordic chips and zigbee.
I am evaluating a possible configuration for a Zigbee coordinator and I verified that...
When including RNG configuration I am getting the error: Warning[Li026]: the module "sns_silib.c.obj(libnrf_cc310_0.9.13.a)" (and 15 other modules) do not contain information...
I am trying to program MS12SF1 module through nrf5340DK. I tested the blinky code to toggle the LED pins but while checking through oscilloscope the pins showed nothing, wasn...
Hi
I am stuck using a proximus M2M sim card with the AWS-IoT sample. I did get it working with an Ibasis sim card but now I want to use a Proximus M2M sim card but I keep...
I connected one external BH1749 sensor with nrf5340DK and was testing it with the bh1749 sample code but the sensor is only getting initialized and I am getting [00:00:00...
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
While using Visual Code I have noticed that:
First compile always generates errors, which is fine. The error notifications are persistent even after they have been fixed...
I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via...
I used this guide to add FOTA over BLE for nRF5340.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/device_guides/working_with_nrf/nrf53/nrf5340...
Hi there,
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance...
Under bootloader/mcuboot/boot/zephyr there is a prj.conf and prj_miminal.conf. By default mcuboot uses the prj.conf. I'd like to know if:
it is possible to configure mcuboot...
I am developing a custom nrf5340 board design, that is using the BL5340PA external antenna module to implement the nrf5340 chip in the design. The BL5340 module allows all...
Hi all,
I am trying to flash the nRF 5340 Audio DK boards with the nRF5240_audio sample. When using the buildprog.py script to flash my three boards, the script fails due...
I have the logging module activated with two backends UART and RTT. The SHELL module is using UART. I'm trying to control the SHELL UART logging backend at runtime,...
