Due to the increase in functionality, the amount of new application code has increased. After DFU operation, FDS Init failed to restart. However, if I use the complete hexadecimal...
Hi, I try to connect ble devices to my iphone. I can send hid data over bluetooth but virtual keypad is hiding. I cant open it. I tried to send 0x65 data as hid report but...
I am using the nRF9160 aws_iot sample. I was now trying somethings that are not optimal situations.
For example, I made some FIFO buffer to write in measurements in one...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
I am working on a project that requires my MCU to have a sleep and awake cycle. I have noticed that when my MCU sleeps (by using k_sleep() in threads) the UART peripheral...
I have got accel data from adaxl345 in nrf9160. I want to get vibration frequency (HZ) from accel data set using fft algorithm.
process:
1. collect 100 accel data every...
Hello.
I try to connect SPI memory W25Q80 to nRF52840DK (in the future it will be my own board) but I have problem with device tree. I modified original files (nRF52840dk_nRF52840...
Hello everyone,
I have questions. I am trying to scope 32mhz external clock on osilloscope that gwınstek gds-1062 and I show this two picture. First is at 250ms time/div...
Dear Support team,
I'm involved in the activity to migrate to NCS a project already developed & successfuly tested with using nRF52 SDK v17.1.0, over the custom board initially...
we are developing custom hard fault handler to get its information during non-debug mode. In order to collect the information in non-debug mode we are trying to store...
Hi guys:
Right now I have my custom board using nRF52833.
I wang to use DFU over uart to upgrade firmware.
I try a different way to enter DFU mode, and this require...
Hello everyone,
I'm presently working on a project that employs the nRF Connect SDK 2.6.0 in a Bluetooth Mesh application. My task involves a requirement to increase the...
i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
I am trying to figure out how to change the automatic gain settings on the on-board microphone. It is connected via its I2C to the hardware codec, but apparently not...
Hi Team,
Can you please provide your inputs here.
1. Is the nRF9160 SLM supports NIDD(non-ip data delivery)? If yes, can you please provide the AT commands to configure...
I'm encountering an issue with the Matter template code in nRF Connect SDK v2.6.0 on my custom board. Strangely, the same code runs perfectly fine on my board when using the...
We are interested in the NPM1300, but I would like to know the standby or basic current consumption of the buck converters VOUT1 and VOUT2 when there is no load, with...
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
I'm looking to create a custom board with MDBT50Q-1MV2. Can I directly power it from a LiPo battery (3.7V - 200mAh) only to the VDDH pin? My board is very compact, so I want...
Greetings,
After migrating to the NCS v2.5.2, I noticed a warning that recommends using static partition management (which I have also confirmed is recommended by other...
