Hello, I am trying to get the asset tracker v2 working on the DEV board nRF9151-DK.
I have got the asset tracker v2 to compile , and also started the process with the at_client...
I recently bought this display that is 64x32 pixels and uses the SSD1306 driver . When running the LVGL Basic Sample with the Zephyr ssd1306 _128x64 shield , the display works...
Occasionally over the years we see suggestions to turn off and turn back on the undocumented power control bit for various peripherals to get around typically unexpectedly...
I have Micromod nRF52840 module on a carrier board and I've built and flashed Matter Light Switch sample on it but I need to read the logs from the module
How can...
Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
I am interested in creating a Bluetooth application to create a piconet (i.e. multi-link central). I found this sample application that uses the nRF5 SDK rather than...
The PPK2 is always on COM4 on my Windows 11 machine, and I can't seem to change it. I bought a 2nd PPK2, and when I plug them both in, they are both on COM4. There is no ...
Hi Nordic Team,
I've got the nrf coded phy hr example working using 1.5.1 nRF Connect SDK, with the peripheral and central sides running on a couple of nRF52840-DK's.
We're using the nRF52840 with Zephyr in the nRF Connect SDK. Our current firmware build is using the SDK v2.3.0.
For some important BLE links we're using the Coded PHY ...
Hi all,
Can someone refer me to a document that details this:
What is the product life expectancy for the nRF52840 from 2024? At least another 10 years?
Thanks!...
I am recently trying to get up and running with the nrf9160-DK and have been unable to flash the board successfully even with the Quick start (v0.2.6) app in nrf Connect....
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
Hello Nordic Support Team,
I hope this message finds you well. I'm writing to seek your assistance as I've encountered an issue with my PPK2 device. Regrettably, due to...
How can...
Hi there!
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
Trying to implement FOTA DFU over BLE. My application uses my proprietary code (instead of mcumgr) to download signed OTA firmware image to secondary slot (in my case it is...
Hello, we have a product that uses the NRF52832. We recently detected that the device will randomly increase its current consumption by about 260uA during sleep mode. Once...
