On a nrf52840 (sdk 16.0.0) I have sporadically an unexpected behaviour when I unprovision my device, both with the nRF Mesh and with our custom app. As showed in...
I trying to generate dfu images following the procedure described below:
https://novelbits.io/nrf52-ota-dfu-ble-part-4/
the procedure to generate files is ok,...
Hello to everyone,
I'm pretty in new in developing with Nordic chips and zigbee.
I am evaluating a possible configuration for a Zigbee coordinator and I verified that...
When including RNG configuration I am getting the error: Warning[Li026]: the module "sns_silib.c.obj(libnrf_cc310_0.9.13.a)" (and 15 other modules) do not contain information...
I am trying to program MS12SF1 module through nrf5340DK. I tested the blinky code to toggle the LED pins but while checking through oscilloscope the pins showed nothing, wasn...
I'm working on an application where we're implementing the nPM1300 and utilizing the fuel gauge algorithm to estimate battery life. Interestingly, the results that...
Hi everyone,
My question is basically the title. I am trying to do extended advertising with my nRF5340, using the direction finding connectionless tx sample. However, I...
Hi, when I use other modules (like NRF_LOG ecc) no problem, when i use UART or UARTE the script is ok but i can't see anything on PuTTY terminal. In my case, a LED should...
I am using the GUI app.overlay program to modify the pin locations. I changed the UART0 pins to be P0.00 to P0.03 (from P0.05 to P0.08) so I could free up the default pin...
Dear Support Team I cant build the application for nRF5340. Following all iinstallation prerequisites and examples i get stuck.
I always get this error message:
PS C:...
I am in the process of making a custom service for a peripheral I am developing. I have some data that I would like to have in the same characteristic because it will be retrieved...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
What are the parameters affecting the Thread network range other than the TX power ?
I am using Micromod nRF52840 module , to test Matter Light Bulb and Matter...
Hi there,
I'm currently working on the firmware versioning and the downgrade protection for an nRF5340 with NCS 2.6.0.
The firmware consists of:
I currently have...
I have configured NRF52840 as coordinator ,EFR1 (ENDDEVICE) and EFR2(ENDDEVICE) as end devices. These 3 devices are connected in network.EFR2(End device )continuously sending...
I have two nRF52840 devices one peripheral and one central. Both devices feature the Nordic Uart Service. They are based on ble_app_uart example and e nrf52-ble-app...
Hello to everyone,
Hi.
I have integrated the NFC samples (nRF5340 DK) into the audio headset app (nRF5340 ADK), using SDK 2.5.2.
For simplicity I've created two builds, a central version...
Dear Nordic Support
Recently I have the issue that the nrf-connect.toolchain.path, set in the VS-Code workspace file, doesn't correctly resolve if predefined VS-Code variables...
