I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
Today I am attempting to set up an MQTT connection from a Thread device to an MQTT server on the Internet (for better or for worse, if this is a terrible idea I'm open to...
Very new to Zigbee. Trying to use nrf 5340 dk as a Zigbee Coordinator to connect to a Thirdreality and a Sonoff PIR motion sensor. No modification (expect adding...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
Hello Team Nordic,
Does nRF9160 support Remote Network Driver Interface Specification ( RNDIS)?
The customer ask if nRF9160 supports RNDIS driver due to transfer data...
Hi supporter
I try to connect nRF5340-DK and extenal board(nRF7002 and nRF5340 combo modules) from P20, programming and debug was failed as below.I check the VEXT>nRF switch...
I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
I am trying to drive my OLED by nrf52833DK.
The OLED is offered by online shop that with a description that SSD1306.
I don't know whether the drive is offered in zephyr...
hey! So i require some guidance regarding the implementation of system ON low power mode in my sdk. 1. I have configured interrupts for all button press, so that the interrupt...
I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb' 254 ...
Hi, I recently installed the last version of the SDK v2.5.2 and when I try to build the sample direction_finding_central I am getting the following error
I am running...
Hi all,
I am new to the nordic controllers and ANT+ protocol.
And I am going to evaluate ANT+ protocol in nrf52dk board (nRF52832 controller).
I need to understand which...
Is there any way I can enable Read /write protection from Jtag for NRF BC52805M
I am looking for something like (ST RDP protection level 2) where once we flash...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
Hello, I am trying to communicate with a Bosch BMI 270 device( datasheet ) using the nrf5340dk. I macgyvered something together from the bmi270 file in the zephyr/sensor folder...
Hi all,
I'm using the NCS 2.5.2 sdk and nrf 5340 with 7002, and I want to do BLE OTA DFU using external flash.
I've found this guide Add DFU support to your application - Software...
Hello Team Nordic,
I recently bought this display that is 64x32 pixels and uses the SSD1306 driver . When running the LVGL Basic Sample with the Zephyr ssd1306 _128x64 shield , the display works...
