I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
Hello, Karl Ylvisaker. When I use 52840 scan, I sometimes fail to scan other Bluetooth devices for a long time, but the scan will resume after a long time. Other Bluetooth...
hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
I would like to be able to dynamically enable & disable APPROTECT from a zephyr application at runtime, not via Kconfig. Is there existing driver support for this feature...
In working thru the Nordic Academy Intermediate lessons on DFU, it was very instructive to use the mcumgr command line interface to see exactly what's happening on the device...
hi
I am configuring a product using nRF52832 and NUS.
This time, I'm trying to view BLE wireless data (raw) from central and peripheral, but I can't find a way to do...
Hi Everyone,
I am using NRF52833 QFN-40 Package. As I know in datasheet, they have mentioned two I2C Channel is available. I am just curious is for all packages of NRF52833...
I tried implementing a PDM interface for recording sound from a microphone on the nrf52840. For this purpose, I used the official example which is accessible at github.com...
Hello Nordic support, I work on receive data from the microphone mp34dt05-a . I have some question. 1- How to enable PDM in SDK_CONFIG.H . 2- For this project do I need enable...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
I'm attempting to generate a binary blob containing both the S140 SoftDevice (to be placed at address 0x1000 in flash) and the main application firmware (at 0x26000).
I...
hi,I am using the NRF52840, softdevice: s140,
If a Bluetooth host simultaneously connects to multiple Bluetooth peripherals, and the peripherals transmit data to the host...
hello,
I made a development board using the nrf52840 module.
What methods are there to measure power consumption?
I know of two methods: measuring with the Power Profiler...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
I'm using the custom board of nrf 5340 with 7002.
When I run the sample project of Hello World, the current is about 90 ma,
and I run the sample project of WI-FI Scan...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
I have a Temperature and Humidity Zigbee Sensor, link is here: https://www.aqara.com/us/temperature_humidity_sensor.html
Now I use nrf52840 kit as coordinator and use the...
Hello.
I'm developing some kind of wearable device with using nRF52832.
I'm using Segger Embedded Studio for developing.
I write my code by modifying ble_app_template...
