I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
In all the bluetooth samples for the nrf5340, whenever the configuration is set to the cpuapp board, a child image automagically built from the "hci_ipc" sample. What do I...
I have the logging module activated with two backends UART and RTT. The SHELL module is using UART. I'm trying to control the SHELL UART logging backend at runtime,...
We are developing for the NRF5340 and Zephyr (SDK 2.5.0). As we approach the first preproduction run, we are realizing we need a better way to set device names than...
I'm testing the IQ feature of the radio test. According to the documentation on https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/wifi/radio_test...
Hi all,
I have a SPIS implementation on an nRF52840 running smoothly. Recently I'v had the need to receive large packets (up to 270 bytes) in one single transaction. However...
We've developed a custom PCB featuring the nRF52840 Core Chip, but we're encountering significant challenges with antenna performance, resulting in poor range during...
Hi supporter
I try to connect nRF5340-DK and extenal board(nRF7002 and nRF5340 combo modules) from P20, programming and debug was failed as below.I check the VEXT>nRF switch...
https://devzone.nordicsemi.com/f/nordic-q-a/44658/communication-probl
I want to change the code provided in this link to enter the password from the peripheral
I am using PCA10056 for external debugging. When I connected PCA10056 to the external NRF52840 module board for debugging and then transferred it to another module,...
Anyone has experience with NCS with ANT+ with FEM? I have a project on nRF5340, NCS 2.4.1, with BLE and ANT+ working... Later on we need to add a FEM to the board, this is...
I am using SDK 2.3.0. I have recently enabled child supervision in a system with one FTD and many SEDs. I am testing backward compatibility with older FTDs which doesn...
Hello.
I am developing an SPI FIFO reading program with a accelerometer. with sdk17.1.0
It runs well on nrf52840 devkit but it stuck at nrf52832 devkit.
And I found...
Hi
I have been looking into this for a while and might just be missing something silly but I would appreciate any help. Our application uses a modified nrf cloud multi service...
I'm experiencing an intermittent problem where nRF9160 devices aren't able to establish an LTE connection. Recently our SIM provider made a configuration change that...
Hi there
I'm working on nRF5340 chip and looking for a way to preserve the factory data that is saved in factory_data region. I tried playing around with the factory data...
Hello, I'm trying to provision nRF9160 DK in nRF Cloud using https://docs.nordicsemi.com/bundle/nrf-cloud/page/SecurityServices/ProvisioningService/ProvisioningOverview.html...
Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
What are the parameters affecting the Thread network range other than the TX power ?
I am using Micromod nRF52840 module , to test Matter Light Bulb and Matter...
We have a BLE, battery powered device where we'd like to enter low power modes whenever possible by dynamically switching between HFXO and HFINT such that our application...
