Hi Team,
Can you please tell the AT commands of below.
1. AT command to keep nRF9160 in sleep mode.
2. AT command to wakeup nRF9160.
Sravan Rikka
We are trying to Perform DFU to nrf52840 from ESP32.Is there any Master DFU Code in the nrf SDK so that we can port this code to ESP32 IDF and perform DFU from ESP32...
how to convert/format NCELL data to data that you can use to find the cell on a cellmapper.
This is a ncell result: %NCELLMEAS: 0, “06223A0C”, “20610”, “5334”,65535...
Our product need CE approval. For that the radio must be set into an active transmitting mode among other. I have read the radio_test example is a good option.
To get a...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
Dear Support Team,
Hardware : nRF5340 Custom board
Software : nRF Connect SDK v2.2.0
I have implemented OTA FW update for nRF5340. I've used multi-image simultaneous...
Hi Team,
Sravan Rikka
Hello everyone! I'm trying to implement the usage of accelerometer LIS3DH on a custom board. My board has nRF52832 microcontroller as the brain and a few ICs for different...
Unable to use uart ,I2c,SPI together as shown in the error message. I am attaching the dts overlay file
Is there any way to use all UART,SPI,I2C together. Please let me...
We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
hey! So i require some guidance regarding the implementation of system ON low power mode in my sdk. 1. I have configured interrupts for all button press, so that the interrupt...
I am trying to program MS12SF1 module through nrf5340DK. I tested the blinky code to toggle the LED pins but while checking through oscilloscope the pins showed nothing, wasn...
I'm trying to use the Observer example in zephr-sdk-0.16.5 to work with beacons that only use long range coded phy mode. I've updaed prj.conf to take what I believe to be...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
To get a...
Hi all,
NRF5340 NRF Connect 2.6.0
We would like to perform the following operations on the NRF5340: * Read FICR.DEVICEADDR (BLE random MAC is also fine). * Set the BLE...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
