Is there any mechanism to identify device relationship (parent , child relationship).
Do nRF Mesh maintain any topology?
Thanks in advance.
Robert...
Hi supporter
Iuse two DK boards for nRF7002-DK & nRF5340-DK, SDK version is V2.5.2, sample code nrfx_spim_spis_nonblocking in C:\ncs\v2.5.2\modules\hal\nordic\nrfx\samples...
Hi all,
I am designing a wearable device with a strap (concept as attached image)
I plan to design the RF antenna on the flex PCB and then place it inside the strap (strap...
example:ble_app_uart + secure_bootloader sdk:17.1 hello. Well, a strange phenomenon occurred when I was testing the connection between our ble device and the app。 Our app...
The welcome page
for nRF connect extention pack does not appear anymore.So not able to compile and run programs.
Also noticed that the compilation works with...
hi support team,
how to use flash partial operation for nrf sdk 17.1 and soc 52840? i have tried below code, but it still stop usb to receive data from pc very quicky, for...
I have the task to integrate MCUboot in a project that will be deployed on a nrf5340. I've enabled MCUboot using KKonfig option `CONFIG_BOOTLOADER_MCUBOOT`. According...
Good evening,
I am working on a project using a customized board with nrf52840. The project is built on MBed. I am trying to switch to nRF Connect SDK. The first step is...
I have completed a project based on nrf52840 as a peripheral device.
These days, i am expirementing with nrf52840 as a central device. I have successfully scanned...
I have a project working on Nora B1, which I am testing on nrf5340DK. It is based on the Peripheral UART Sample, programmed with nfr Connect SDK v1.9.1. Now I need...
Hye everyone, thanks for the project i have a problem on NRF52840 on a project using mcuboot (ota) and an external flash used independently by the app (not for ota)
prj...
Hi, I am currently working with the nRF9160DK board, using SDK version 2.5.1, and I have encountered an issue regarding connectivity to the AWS IoT cloud.
I have successfully...
Hello guys,
I'm utilizing an EVK-ANNA-B402 module, which includes an nRF52833 microcontroller with Zephyr OS, and I'm exploring ways to enable bidirectional communication...
Thanks in advance.
Robert...
We are doing a project on nRF52832 which uses UART for QR-code sensor, I2C for OLED and SPI for external flash.
The code works fine as expected when tested in nRF52832...
Im currently planning to move a project i did in nrF52833DK to nrF52840DK.
My project uses the thread protocol. and relevant DHT11 files.
So i directly added the...
Hi supporter
Hi all,
The welcome page
Hi there, I need to collect modem logs to investigate LTE-M connectivity issues in specific countries. I have been using the command AT %X MODEMTRACE=1,2 to activate them...
I am currently having an issue with my custom board.
I am getting CEREG 4. it is difficult to tell from the documentation if this is:
4 – Subscribe unsolicited...
