I just recently got a nRF52840 board and tried to flash a nrf connect firmware (I built it myself and the firmware itself does work correctly) onto it. But I noticed...
Hello, I'm trying to provision nRF9160 DK in nRF Cloud using https://docs.nordicsemi.com/bundle/nrf-cloud/page/SecurityServices/ProvisioningService/ProvisioningOverview.html...
How do I get the value of the characteristic of the service I created? I try to get it with the following code, but the content pointer returned is NULL.
I have implemented the heartrate on central side which notify the measurement value and that can be read from peripheral , now my dought is that is it possible to implement...
Starting from the AWS IoT sample, I’m having a hard time configuring the connection before calling net_if_up() which abstracts a lot of stuff. I would like to configure...
Dear Nordic Support
Recently I have the issue that the nrf-connect.toolchain.path, set in the VS-Code workspace file, doesn't correctly resolve if predefined VS-Code variables...
Hi Support Team,
I want to use an external flash(2M byte) to store the sensor data in a 'circular overwrite' way. I now tried it with the FCB(Flash Circular Buffer) on nRF5340...
Dears,
I am just using the nRF52840 SoC for vapor device test board design, currently that we have finished the test board of PCBA samples, but we could not connect it by...
I am dealing with a persistent I2S RX overrun issue in the nRF5340 audio application that is impacting data reception and disrupting communications between the gateway...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
We use the nRF52840 hci_usb sample to emulate a mobile phone App communicating with a product, allowing us to check BLE control of a product and data reported back to...
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
Designing a board with limited space (35-40mm) and need a chip antenna recommendation for the RF transceiver.
Anyone have experience with the Johnson Technology 2450AT18B100...
Hi there,
Zephyr has ability for an Application version management . Based on this, I have created a "Version" file, without any file name extension (like .txt).
Now...
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via...
Hi all , I 'm using NRF52840DK and I want to use RTT to print logging , but I configured a lot of different configs and I can 't print any information in RTT after all . ...
Hi there,
I'm currently working on the firmware versioning and the downgrade protection for an nRF5340 with NCS 2.6.0.
The firmware consists of:
I currently have...
I have a device that runs NCS 2.0.2 on an nrf5340 and have an occasional issue with service discovery.
I have recently found that after calling sys_reboot() on my device...
Hi, I was checking the HAL for SPI in master mode and notice that when pm_device_action_run(<spi_device>, PM_DEVICE_ACTION_SUSPEND); the CS pin isnt changed since it status...
Hi
Can I get some idea on which functions to make changes to in order to scan and report(for example on uart) the number of ble devices present in NRF52832 kit range.
I am working on nRF52833 IC for my application and implemented my code on the nRF52833-DK and tested. Now we designed our custom board as per our project requirements...
