hello,
I recently started research in this area and purchased an nRF52, but I am not very familiar with this field. The PC and nRF52840 are connected via a wired connection...
Dears,
I am just using the nRF52840 SoC for vapor device test board design, currently that we have finished the test board of PCBA samples, but we could not connect it by...
I just recently got a nRF52840 board and tried to flash a nrf connect firmware (I built it myself and the firmware itself does work correctly) onto it. But I noticed...
Hello, I'm trying to provision nRF9160 DK in nRF Cloud using https://docs.nordicsemi.com/bundle/nrf-cloud/page/SecurityServices/ProvisioningService/ProvisioningOverview.html...
How do I get the value of the characteristic of the service I created? I try to get it with the following code, but the content pointer returned is NULL.
Starting from the AWS IoT sample, I’m having a hard time configuring the connection before calling net_if_up() which abstracts a lot of stuff. I would like to configure...
Dear Nordic Support
Recently I have the issue that the nrf-connect.toolchain.path, set in the VS-Code workspace file, doesn't correctly resolve if predefined VS-Code variables...
hi,
I want to know how Bluetooth allocates channel resources as a master.
Assuming a Bluetooth master is connected to 8 slaves simultaneously, how does the master allocate...
Hi, I was checking the HAL for SPI in master mode and notice that when pm_device_action_run(<spi_device>, PM_DEVICE_ACTION_SUSPEND); the CS pin isnt changed since it status...
hello,
Hi there,
I'm currently working on the firmware versioning and the downgrade protection for an nRF5340 with NCS 2.6.0.
The firmware consists of:
I currently have...
Hello DevZone,
I'm trying to run Matter over Thread demo on nRF7002DK. In fact, it's not a real 7002DK, but a simplified version. You can check the documents about this...
I am using SDK 2.3.0. I have recently enabled child supervision in a system with one FTD and many SEDs. I am testing backward compatibility with older FTDs which doesn...
I have implemented the heartrate on central side which notify the measurement value and that can be read from peripheral , now my dought is that is it possible to implement...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
Hi all , I 'm using NRF52840DK and I want to use RTT to print logging , but I configured a lot of different configs and I can 't print any information in RTT after all . ...
While building MultiNUS project with NCS v2.6.0, the following error occurs.
Can you please suggest what we are missing in order to build it successfully
Dears,
I am dealing with a persistent I2S RX overrun issue in the nRF5340 audio application that is impacting data reception and disrupting communications between the gateway...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
We use the nRF52840 hci_usb sample to emulate a mobile phone App communicating with a product, allowing us to check BLE control of a product and data reported back to...
