I configured the Gpio 8 as the Rx of UART. When the UART is Idle, I need to configure the G pi o 8 to be an interrupt pin.
This configuration is fine at all times except...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
I have discovered a bug in the fota_download.c file contained in the SDK. I am attempting to cancel the FOTA update separately within my application code, and it goes...
Hello thats my code
and for a 2 days im completely stuck with reading data from LIS3DH, i guess my functions for writing and reading are fine. my read buff is just uint8_t...
Hi, I am working with the nrf9160 and need to get the current date / time. It looks like overall this is pretty simple to do, but I had a question about local time. Using...
I am using Micromod nRF52840 module on the ATP Board to test Matter Light Switch and Matter Light Bulb and I got poor network signal
I successfully can communicate...
I am trying to read acceleration values from an acceleration sensor (IIM-42652) via SPI with nrf52832 as the SPI master. I created it based on the spi_pca10040 example,...
Hello, I am currently working on nrf52840 using nrf-sdk v2.2. to build a Matter firmware. I encountered an issue that a small number of chips UART received data incorrectly...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
I have an old nRF9160DK from few years back (v0.8.2). I got busy with other things and was not able to work on it.
Now I'm trying to update the modem firmware to the...
Hi Nordic
It has not be found much in Nordic documentation about sniffing/monitoring over-the-air communication of Matter.
Any recommendations are appreciated.
Or, would...
I'm getting timeout errors when trying to program a Thingy:91 with a J-Link Pro PoE on macOS on an ARM Apple M3 Max.
Here's the command and error message:
I get the...
I am writing to seek assistance with an issue I've encountered while attempting to create a modem trace on my nRF9160DK board.
When flashing my asset tracking code...
The Central device is using Resolvable Private Addresses.
Even though private_addr_cycle_s is set to BLE_GAP_DEFAULT_PRIVATE_ADDR_CYCLE_INTERVAL_S (15 minutes),
When observed...
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in...
I am using nRF Connect SDK V2.3.0. How can I power down the UART?
I am using the Interrupt-driven UART API, interrupt driven on RX and polling on TX. I have disabled...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
