I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
Today I am attempting to set up an MQTT connection from a Thread device to an MQTT server on the Internet (for better or for worse, if this is a terrible idea I'm open to...
Very new to Zigbee. Trying to use nrf 5340 dk as a Zigbee Coordinator to connect to a Thirdreality and a Sonoff PIR motion sensor. No modification (expect adding...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
Hello Team Nordic,
Does nRF9160 support Remote Network Driver Interface Specification ( RNDIS)?
The customer ask if nRF9160 supports RNDIS driver due to transfer data...
Hi supporter
I try to connect nRF5340-DK and extenal board(nRF7002 and nRF5340 combo modules) from P20, programming and debug was failed as below.I check the VEXT>nRF switch...
I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
Hi
Can I get some idea on which functions to make changes to in order to scan and report(for example on uart) the number of ble devices present in NRF52832 kit range.
We are working with nRF5340 with SDK v2.5.2.
Each time we try to program the board, we get below error.
We do not see this error if we try Erase and Flash option...
I am trying to drive my OLED by nrf52833DK.
The OLED is offered by online shop that with a description that SSD1306.
I don't know whether the drive is offered in zephyr...
hey! So i require some guidance regarding the implementation of system ON low power mode in my sdk. 1. I have configured interrupts for all button press, so that the interrupt...
I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb' 254 ...
Hi, I recently installed the last version of the SDK v2.5.2 and when I try to build the sample direction_finding_central I am getting the following error
I am running...
Hi all,
I am new to the nordic controllers and ANT+ protocol.
And I am going to evaluate ANT+ protocol in nrf52dk board (nRF52832 controller).
I need to understand which...
Is there any way I can enable Read /write protection from Jtag for NRF BC52805M
I am looking for something like (ST RDP protection level 2) where once we flash...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
Hello, I am trying to communicate with a Bosch BMI 270 device( datasheet ) using the nrf5340dk. I macgyvered something together from the bmi270 file in the zephyr/sensor folder...
Hi all,
I'm using the NCS 2.5.2 sdk and nrf 5340 with 7002, and I want to do BLE OTA DFU using external flash.
I've found this guide Add DFU support to your application - Software...
