What is the impact of the power cut off immediately to the chip?
1. Will the power drop immediately to ground?
2. Does the power cut off immediately have risk of firmware...
Is there any way I can enable Read /write protection from Jtag for NRF BC52805M
I am looking for something like (ST RDP protection level 2) where once we flash...
I am using SDK 2.3.0. I have recently enabled child supervision in a system with one FTD and many SEDs. I am testing backward compatibility with older FTDs which doesn...
I am working on a custom board that currently has an nRF21540 that is connected on the SPI bus of nRF5340, that is also connected to a number of SPI slave devices controlled...
I used this guide to add FOTA over BLE for nRF5340.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/device_guides/working_with_nrf/nrf53/nrf5340...
I am migrating one of Segger Embedded Studio based project to NRF Connect SDK for nrf53 series of board.
I migrated the function that uses GPIOTE feature using relevant...
ble peripheral and central both is nrd52840.softdevice is nrf52.7.2.0. peripheral PHY is 2M ,peripheral send 160K bytes data needs 14 senconds.how to increase the transport...
I am trying to read acceleration values from an acceleration sensor (IIM-42652) via SPI with nrf52832 as the SPI master. I created it based on the spi_pca10040 example,...
Hello!
I'm trying to run an example from the course: Exercise 3 – FOTA over Bluetooth Low Energy . Everything is built without any problems, I use nRF Connect SDK version...
I have the nRF52840 USB dongle, and I want to set up Wirepas by flashing the .hex file. Do I need to set up the nRF5 SDK or Segger EMbedded studio (SES) for this process on...
Hi all , I 'm using NRF52840DK and I want to use RTT to print logging , but I configured a lot of different configs and I can 't print any information in RTT after all . ...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
Hello All,
I am using nrf52805M from fanstel (LINK) , and code which is based on nrf sdk softdevice S112.
Things works great normally, but in order to satisfy the cyber...
We are interested in the NPM1300, but I would like to know the standby or basic current consumption of the buck converters VOUT1 and VOUT2 when there is no load, with...
As Pevious ticket: Using NRF24L01+ with pure assembler programing becomes very long, I open a new one as Torbjørn suggested
This is a description about what I have doing...
Hi everyone,
In a project, i am trying to use only channel 38 for extended long range advertising.
Is it possible select only one advertising channel using channel masks...
