Hello I am utilising the nrf5-sdk and have used the ble_peripheral/ble_app_uart example as a reference. I am using a 2MBPS PHY, an ATT MTU of 247, and a connection interval...
Hi Nordic,
I am coding a program (TCP client) sending an array of bytes to a server over TCP. There is no error during the building process. And, there is also no error...
Hi everyone,
In a project, i am trying to use only channel 38 for extended long range advertising.
Is it possible select only one advertising channel using channel masks...
Hi, I was checking the HAL for SPI in master mode and notice that when pm_device_action_run(<spi_device>, PM_DEVICE_ACTION_SUSPEND); the CS pin isnt changed since it status...
Hi everyone,
I am trying to listing mobile phone using BLE(nrf52833 and software: ble_app_uart_c). I have downloaded nrf connect app on android and then i scanned and...
Due to the increase in functionality, the amount of new application code has increased. After DFU operation, FDS Init failed to restart. However, if I use the complete hexadecimal...
Our team has encountered an intermittent issue when attempting to connect to our nRF device (nRF52833) using the nRF Connect Desktop BLE app. This issue does not occur...
Hello, we have a product that uses the NRF52832. We recently detected that the device will randomly increase its current consumption by about 260uA during sleep mode. Once...
1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
1. am currently using the nrf9161_dk. and have not modified the modem FW in anyway.
2. I am using the vscode extension provided by nordic to build/run this sample
a, i...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
Hi Nordic,
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
Hi, I am new to PCB design, so I want suggestions for my designed PCB. Please review it once and provide feedback upon that. I am making this PCB to use this with Thread and...
Hi, Im working in nrf9160dk, I'm referring aws iot document there they given a code 6278.aws_iot_tutorial.rar there im getting this error .what i need to do?
Executing task...
Hello, I am currently working on nrf52840 using nrf-sdk v2.2. to build a Matter firmware. I encountered an issue that a small number of chips UART received data incorrectly...
I am trying to run the Direct Test Mode on a custom board. We have two boards revisions, one with a nRF52832 and one with a nRF52811. I managed to build the DTM for...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
Hi everyone,
