Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
Dear Support Team,
Hardware : nRF5340 Custom board
Software : nRF Connect SDK v2.2.0
I have implemented OTA FW update for nRF5340. I've used multi-image simultaneous...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
Unable to use uart ,I2c,SPI together as shown in the error message. I am attaching the dts overlay file
Is there any way to use all UART,SPI,I2C together. Please let me...
we can't open docs.nordicsemi.com in chrome without setting it to: Sites can send pop-ups and use redirects
We don't want to do that for all sites, so we tried adding...
hello Nordic
i am working with ncs v2.5.0 with nrf52840
i am using lfs to save the device configurations in a file
when reading this file i need to allocate a buffer...
Hello!
I'm trying to change the output TX power in the nrf5340 audio dk. I'm setting:
CONFIG_BLE_CONN_TX_POWER_NEG_40DBM=y
CONFIG_BLE_ADV_TX_POWER_NEG_40DBM=y
I have two nRF52840 devices one peripheral and one central. Both devices feature the Nordic Uart Service. They are based on ble_app_uart example and e nrf52-ble-app...
Dear Support Team I cant build the application for nRF5340. Following all iinstallation prerequisites and examples i get stuck.
I always get this error message:
PS C:...
Hi, I'm configuring my proprietary AOA radio, and I have consulted the white paper and the Product Specification, but I did not get enough useful information.
I want to...
Hi. I am working on upgrading an old project made for NRF9160 to NRF9161. a Requirement that seems to require upgrading Zephyr/NRF SDK and this 10000 lines of application...
Hi Devzone,
I want to know if I can use the dongle BLED112 with the bluetooth low energy app.
If not, which one should I consider?
I am trying to replicate the experience given...
I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
hi,
1、How can I setting cipher suite version? When I was doing tls bidirectional authentication.
I can't find the AT comand. thanks a lot !
AT #XMQTTCON=<op>[...
I am using nrf52840 and i am working on nrf connect sdk v2.6.0 in my overlay file SPI CS pin is low but it is going high between the communication. Data is not receiving from...
Hi all, i have some problem while i try to estabilish an LTE connection . I'm using nordic n9160dk. I just search through the site, and i see a lot of topic like this , or...
I would like to be able to dynamically enable & disable APPROTECT from a zephyr application at runtime, not via Kconfig. Is there existing driver support for this feature...
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
I want to read data from 8 channels of ADC, when configuring all channels it shows that some of the pins are pre-occupied by other nodes. i have applied different things to...
Abnormal power consumption is observed after using sd_temp_get to retrieve the MCU temperature on the nrf52840.
**SDK Ver: SDK17
**Source Code:
temperature.c
float...
