Hi there
I'm working on nRF5340 chip and looking for a way to preserve the factory data that is saved in factory_data region. I tried playing around with the factory data...
Hi,Nodic!
We are now using nrf5340, ncs2.5.0 to do the project.
We are using disk mass storage with a filesystem mounted on an external memory device.Now I see that this...
I believe that when the nRF5340 operates in LE-Audio CIS mode, the Gateway and Headset are connected, but where is the bonding information set in the source?
I am thinking of developing it by reusing the nRF5340 DK circuit and the nR5340_Audio sample program. I don't know where the nRF5340's switches and LED pins are assigned in...
1. am currently using the nrf9161_dk. and have not modified the modem FW in anyway.
2. I am using the vscode extension provided by nordic to build/run this sample
a, i...
I've followed the reference circuitry pretty explicitly ( here ), however, I want to confirm that this configuration will give me DCDCEN1 capability for power supply consumption...
Hello, there seem to be a lot of technical details missing from the datasheet. In my case, I really need to know the capabilities of the load switches such as reverse current...
I'm trying to develop a Zigbee application for the Seeed Xiao nRF52840 BLE board.
I can compile the "Blinky" demo app in nRF Connect for VS Code and run it on the board...
Hi there
Hi,Nodic!
I need to update a custom bootloader from the main application running on an nRF52840. The bootloader is contained in 0xF0000 to 0xF90D7 in internal flash, and the S140 SoftDevice...
CIS mode using the nRF5340 Audio application We are considering implementing a bidirectional stream.
Edit prj_release.conf as below and build/write I did it using a script...
I am recently trying to get up and running with the nrf9160-DK and have been unable to flash the board successfully even with the Quick start (v0.2.6) app in nrf Connect....
I'm trying desperately to find a way to restart a debugging session (reset device and go back to main) on the nrf9160dk without reloading the FW onto the device.
I'm using...
In Matter 1.1, I previously encountered the TC-RR-1.1 issue, which was resolved by changing the setting_storage partition size from 16KB to 32KB.
However, in...
Hello! I try build example from new SDK 14.1.0 in Keil5.
But I get a error Cannot execute external request (Install Pack, NordicSemiconductor:nRF_DeviceFamilyPack:8.15...
I am using a PCA10056 Dev Kit to test the accel sensor(IIS3DWB). But the SPI transfer is stuck at the line below.
Here is more information.
1.ST provided an official...
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in...
I'm using a Windows 11 IBM computer. I have gone thru the Dev Academy exercise 1. I installed the software's, nRf for Desktop, nRF Connect SDK, its toolchain, VS Code IDE...
Hi, I need help with these tasks in Lesson 2 ex 2 (step 7. and 8.)
Looking for that path and python file everywhere, unable to find it, I don't have zephyr folder, none...
