I have some questions regarding the RF path of nrf5340-CLAA (WLCSP package):
1. The impedance of the transmission line in the reference design, as calculated using AppCAD...
SDK: 17.1.0
Chip: NRF52832
IDE: Segger Embedded Studio v5.10d
Developing a bluetooth accessory app for a scale on the NRF52832. Using the ble_nus SDK module.
When...
Hi Nordic team,
I hope this message finds you well. I am currently working on developing applications for custom boards utilizing the nRF Connect SDK v2.4.0, with a particular...
I am trying to build the Serial lTE Modem example from SDK directory C:\ncs\v2.5.1\nrf\applications\serial_lte_modem in VScode then resulting the error:
-- Found...
Hello Nordic Engineer,
I used SDK17.1.0
First chip is examples \ ble_central_and_peripheral \ experimental \ ble_app_multirole_lesc
Second chip is examples \ ble_peripheral...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
I was wondering if there is away to perform DFU using SPI without smp protocol or mcumgr from one nRF52840 to another? What I am trying to do is to send a firmware...
SDK: 17.1.0
Chip: NRF52832
When...
I have a project working on Nora B1, which I am testing on nrf5340DK. It is based on the Peripheral UART Sample, programmed with nfr Connect SDK v1.9.1. Now I need...
Hi Nordic team,
-- Found...
We're using nRF Connect with SDK v2.4.0 (Zephyr). Central and peripheral roles combined.
Custom hardware, with Fanstels module BT840
All was working well, but after extensive...
Good morning!
I hope you will forgive my trivial question but I am a beginner. I don't quite understand the partition structure presented in the "NVS" example. Using the...
I used SDK17.1.0
Hi, We are testing in two cellular service regions, one with LTE-M support and one with NB-IoT support. Following the instructions from this ticket devzone.nordicsemi.com...
we've run into an issue using the SPI master (SPIM). We got the NRF5340 connected to our FPGA using 2 spi busses. The NRF is SPI master on one bus and SPI slave on...
I am currently looking into setting up a Matter project (based on the template) and reached ZAP and the required files. As far as I understood, the ".zap" file is the...
I have the task to integrate MCUboot in a project that will be deployed on a nrf5340. I've enabled MCUboot using KKonfig option `CONFIG_BOOTLOADER_MCUBOOT`. According...
We tested the transmitter and found out that it operates only on 700MHz. Why is that?
The other modems operate on at least four frequencies (800MHz, 1.7Ghz, 1.8Ghz, 1.9Ghz...
