We are currently working with Zigbee coordinator sample SDK version 2.1.0. When attempting to write data to a unavailable device, the stack sends an unimplemented signal four...
Hi Team,
Can you please tell the AT commands of below.
1. AT command to keep nRF9160 in sleep mode.
2. AT command to wakeup nRF9160.
Sravan Rikka
Our product need CE approval. For that the radio must be set into an active transmitting mode among other. I have read the radio_test example is a good option.
To get a...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
Dear Support Team,
Hardware : nRF5340 Custom board
Software : nRF Connect SDK v2.2.0
I have implemented OTA FW update for nRF5340. I've used multi-image simultaneous...
we can't open docs.nordicsemi.com in chrome without setting it to: Sites can send pop-ups and use redirects
We don't want to do that for all sites, so we tried adding...
I am unable to add FEM support to nRF21540, Running on ncs 2.6.0 Vscode Zephyr. I am using BLE Peripheral_hr sample. I was following this doc .
This is my error
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
I have a nRF9160DK board that is used for development of a custom nRF9160 board. The hardware designers have assigned GPIO P0.27 to be a general purpose output pin. This pin...
1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
We are trying to Perform DFU to nrf52840 from ESP32.Is there any Master DFU Code in the nrf SDK so that we can port this code to ESP32 IDF and perform DFU from ESP32...
Hello to everyone,
I'm pretty in new in developing with Nordic chips and zigbee.
I am evaluating a possible configuration for a Zigbee coordinator and I verified that...
We recently got the NRF9151-DK and were trting to measure the e-DRX current on the system working on CAT-M1 network. The NRF9151 DK is loaded with Serial LTE Modem application...
I want to read data from 8 channels of ADC, when configuring all channels it shows that some of the pins are pre-occupied by other nodes. i have applied different things to...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
I'm testing the IQ feature of the radio test. According to the documentation on https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/wifi/radio_test...
Hi everyone,
My question is basically the title. I am trying to do extended advertising with my nRF5340, using the direction finding connectionless tx sample. However, I...
We've developed a custom PCB featuring the nRF52840 Core Chip, but we're encountering significant challenges with antenna performance, resulting in poor range during...
Is there any strategy/method or example of how to perform (non Nordic) MCU to (non Nordic) MCU firmware update via UART ? We want the non Nordic chip to do the firmware...
I did the Nordic Academy networking/GNSS online course and had no problems getting GNSS to work on the 9160DK. I'm now trying to get GNSS working on our custom board. The...
How do I get the value of the characteristic of the service I created? I try to get it with the following code, but the content pointer returned is NULL.
