Is it possible to flash the application onto the nRF52840 USB dongle using this method?
https://developer.wirepas.com/support/solutions/articles/77000465762-how-to-flash...
Hi, we are looking to build a bluetooth speaker(Product Prototype) where the mcu using I2S it communicates to the amplifier IC(TAS5806) from TI, Can we use nrf52840 for this...
Dear Sir,
We have 4 Nordic devices connected to 1 central. Device data rate is between 195 to 182 seconds.
I tried changing the following parameters just to understand...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
Hi, I am using nrf52840dk along with Quectel BG95 module with the sample "cellular modem"
Can i able to use the bg95 driver for nrf52840??
When i tried to build it for...
I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
Today I am attempting to set up an MQTT connection from a Thread device to an MQTT server on the Internet (for better or for worse, if this is a terrible idea I'm open to...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
Hi Team
Some times our nRF52 can't received the ACK from border router. But we can see that the border router send the ACK from sniffer data.
which Kconfig can set...
I'm using the NCS 2.5.2 sdk and nrf 5340 with 7002, and I want to do BLE OTA DFU using external flash.
I've found this guide Add DFU support to your application - Software...
I am using nRF52840 which has 2 uarts available. I want to use Modem on UART1. I want to use UART0 for debugging and Bar code scanner at the same time. How can I do that?...
I'm using an Adafruit PDM microphone on nrf5340 audio dk.
The code of the PDM Microphone part has been completed, and I can successfully receive the PDM Microphone...
When using NCS v2.6.0 I have noticed (while troubleshooting other non NCS related problem) that when using LwM2M client utils for location assistance service that support...
I have configured NRF52840 as coordinator ,EFR1 (ENDDEVICE) and EFR2(ENDDEVICE) as end devices. These 3 devices are connected in network.EFR2(End device )continuously sending...
I have a device that runs NCS 2.0.2 on an nrf5340 and have an occasional issue with service discovery.
I have recently found that after calling sys_reboot() on my device...
We use the nRF52840 hci_usb sample to emulate a mobile phone App communicating with a product, allowing us to check BLE control of a product and data reported back to...
Dear Sir,
Hello, I am trying to get the asset tracker v2 working on the DEV board nRF9151-DK.
I have got the asset tracker v2 to compile , and also started the process with the at_client...
Hi, I try to connect ble devices to my iphone. I can send hid data over bluetooth but virtual keypad is hiding. I cant open it. I tried to send 0x65 data as hid report but...
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The...
