Hi nordic team.
im devolep a keyboard using ncs sdk by nrf52840.frist step,i want to Implement a function that my keyboard can be connected to three Bluetooth hosts at different...
Hello, I am trying to get the asset tracker v2 working on the DEV board nRF9151-DK.
I have got the asset tracker v2 to compile , and also started the process with the at_client...
I recently bought this display that is 64x32 pixels and uses the SSD1306 driver . When running the LVGL Basic Sample with the Zephyr ssd1306 _128x64 shield , the display works...
Occasionally over the years we see suggestions to turn off and turn back on the undocumented power control bit for various peripherals to get around typically unexpectedly...
I have Micromod nRF52840 module on a carrier board and I've built and flashed Matter Light Switch sample on it but I need to read the logs from the module
How can...
Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
We had some trouble doing the certification of Tepec, Telec certification requires the RF power accuracy of ±3.8dB , while it is ±4dB in spec。Do you have any good advice
I have installed the nRF Connect SDK v2.0.0 with Visual Studio and can now successfully, build, flash and run the nrf9160 at_client sample application. But when I try...
Hi nordic team.
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
Hi Nordic Team,
I've got the nrf coded phy hr example working using 1.5.1 nRF Connect SDK, with the peripheral and central sides running on a couple of nRF52840-DK's.
We're using the nRF52840 with Zephyr in the nRF Connect SDK. Our current firmware build is using the SDK v2.3.0.
For some important BLE links we're using the Coded PHY ...
Hi all,
Can someone refer me to a document that details this:
What is the product life expectancy for the nRF52840 from 2024? At least another 10 years?
Thanks!...
I am recently trying to get up and running with the nrf9160-DK and have been unable to flash the board successfully even with the Quick start (v0.2.6) app in nrf Connect....
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
Hello Nordic Support Team,
I hope this message finds you well. I'm writing to seek your assistance as I've encountered an issue with my PPK2 device. Regrettably, due to...
How can...
