Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
Hello! We recently acquired a Nordic Thingy:91 for prototyping and it was working great until I came into work this morning and it was no longer showing any signs of life...
After creating a directory in ncs folder, with cmake and source files, i try to add build configuration in VS code, but after the process of building occurs, the build folder...
i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I'm writing an android application, using no.nordicsemi.android:ble:2.3.1. I connect to the sensor and write 49KB data to it. Before recording, I set the desired interval...
we are developing custom hard fault handler to get its information during non-debug mode. In order to collect the information in non-debug mode we are trying to store...
We had a strange problem with a test case of ours. We use the radio in 1Mbps BLE mode and send two packets, then receive one packet.
Our test case normally works, but fails...
My setup is a custom board with a nrf5340 which acts as the BLE Central. When I use a 52833 DK as the peripheral which has the BAS service I can connect and pair using OOB...
Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
for a development project I need to make a USB device HID. I started from the example project: \v2.6.0\zephyr\samples\subsys\usb\hid so on version 2.6.0 of zephyr...
sdk:17.1 example: ble_app_uart+ secure_bootloader. HI I want to do a demo recently. The application scenario of this demo is that in low-power mode, the RTC wakes up every...
In my setup I have one central where several peripherals are connected. I'm using the Multi-NUS service to communicate from the central to the peripherals. Here...
Greetings
I used to be able to program my development boards or my own custom boards but now I get always get an error:
C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\ncs...
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The...
I need to update a custom bootloader from the main application running on an nRF52840. The bootloader is contained in 0xF0000 to 0xF90D7 in internal flash, and the S140 SoftDevice...
Accidentally used a 9V power supply. Board does not flash anymore.
Can still connect to com ports, and onboard led lights up.
Is the board fried or is it stuck in a memory...
Trying to connect an nrf52840 based board to a nrf9160 DK via the J-Link out but always get the following error. Work as expected if I use a nrf52 DK.
Initialising nrfutil...
