I'm having problem with SPI devices using nRF Connect SDK 2.6 with a 9160DK. Following lesson 5 in the intermediate course I get BUS FAULTS when the application starts.
I've been trying to get MCUboot to work with Direct XIP for several days but each time I have a compilation problem:
In fact, I would like to have a project...
Hi,I'm develop with the nRF52840 V17.0.2 ,SD 7.2.0
problem about migrate LVGL 8.1
I have few app_timer ,they are work fine
try to migrate LVGL
alfter lv_init(), app_timer...
I am try to connect AWS IoT MQTT using nRF7002DK. I followed the below link.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/networking/aws_iot...
Hello DevZone,
I'm trying to run Matter over Thread demo on nRF7002DK. In fact, it's not a real 7002DK, but a simplified version. You can check the documents about this...
Hello, support team:
Environment describe: nrf52840,NCS v2.4.0;
I am developint on nrf52840 with openthread.One of the device is thread Leader and others as thread EndDevice...
I am using the I2S slave mode in my nrf52840 based board (seeed studio xiao), I am confused regarding the I2S interface. I actually opened another ticket but nobody seems...
ncs 2.6.0
I'm encountering a weird bus data error when I'm calling psa_generate_random inside a work queue thread (it has name "api"):
The code I'm running...
I built the littlefs zephyr example found in "/zephyr/samples/subsys/fs/littlefs"and then modified it to use the external flash "MX25R64" by adding an app.overlay file. I...
We are evaluating a pedal power meter for bicycle, but have a question we would like some advice.
Usually pedal-type power meters are divided into left and right sides...
I am using nRF52832 board and I want to understand the current consumption in the board will differs while running the code in zephyr RTOS platform and without zephyr...
I'm on a research to find out how I can use synchronization feature only from LTE for other Wireless Sensor Network.
In online profiler page, There's no explanation about...
Hi, I am currently working with the nRF9160DK board, using SDK version 2.5.1, and I have encountered an issue regarding connectivity to the AWS IoT cloud.
I have successfully...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
Hi Team,
I'm using nrf9160. I'm trying to connect to the network by using the nrf9160 controller with in built modem. I'm getting the error code -14 and modem not initialized...
I added CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y to prj.conf file. And adding the following content to pm_static_dfu.yml file. But west build failed.
The following...
try to migrate LVGL
I copied from pm_static.yml from C:\ncs\v2.5.2\nrf\applications\nrf_desktop\configuration\nrf5340dk_nrf5340_cpuapp\pm_static.yml. And adding the following setting in CMakeLists...
After considerable investigation, it seems that using the nRF5340 + nRF7002 combo with some realistic WiFi client comms enabled (eg. using MQTT) results in an image that's...
Hi Nordic
I had used pynrfjprog to update modem of nrf9160 for a long time. Everything ran well and smoothly.
But, yesterday, I found it failed to update modem. I have...
