I have an issue moving my project from SDK v2.5.0 to v2.6.0. Using vscode and changing nothing but the toolchain and SDK version my project will fail to build for the...
NB: I'm not using the full SDK, only the devicetree extension. therefore I must provide the path to zephyr base.
app.code-workspace
This works:
Unfortunately, this is...
I am using nrfconnectsdk v2.4.0 with zephyr and I have a program with a large number of printk() statements.
is there anything in prj.conf that limits the amount of text...
I'm using the NCS 2.5.2 sdk and nrf 5340 with 7002, and I want to do BLE OTA DFU using external flash.
I've found this guide Add DFU support to your application - Software...
I'm using ble advertising function on the board, and using the app on the phone to scan of.
but it has low signal when the phone is very close to it, about only -70 dbm...
I have got accel data from adaxl345 in nrf9160. I want to get vibration frequency (HZ) from accel data set using fft algorithm.
process:
1. collect 100 accel data every...
안녕하세요. 스마트폰 앱에서 이전에 수집한 mac 주소에 ble 광고 없이 연결하여 수집한 mac 주소에 연결할 수 있는 설정이 있나요?
1. ble를 광고와 연결
2. 연결된 ble의 mac 주소를 스마트폰 앱에 저장하세요.
3. 다음 연결에서 광고 없이 수집된 MAC 주소(또는 광고하지만 숨겨진...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
Hi,Nodic!
We are now using nrf5340, ncs2.5.0 to do the project.
We are using disk mass storage with a filesystem mounted on an external memory device.Now I see that this...
I'm looking to create a custom board with MDBT50Q-1MV2. Can I directly power it from a LiPo battery (3.7V - 200mAh) only to the VDDH pin? My board is very compact, so I want...
OS: Ubuntu 20.04.6 NCS SDK: 1.6.1 Segger: 5.50c
I recently got a new laptop, which I installed using the following guide:
https://developer.nordicsemi.com/nRF_Connect_SDK...
we are developing custom hard fault handler to get its information during non-debug mode. In order to collect the information in non-debug mode we are trying to store...
I need to update a custom bootloader from the main application running on an nRF52840. The bootloader is contained in 0xF0000 to 0xF90D7 in internal flash, and the S140 SoftDevice...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
Hi. I have a BLE application aimed to be used with softdevice and SDK17. I use Keil IDE to code and to debug. I flash the soft device first, and then, I can compile/flash...
Discovered on SDK v2.6.0 (latest at time of posting)
Was trying this sample on my nRF52dk board, but was getting a "peripheral not configured" error on key generation. Some...
I'm using nRF52840 DK with ncs V 2.6.0. I plan to create an mp3 or WAV audio player. I tried using the MAX98357A with the i2s nRF52840 DK board, building a project i2s...
app.code-workspace
This works:
Hi everyone,
I am curretly struggling with displaying the heartbeat messages trough UART in mesh.
I used the bt mesh sensor example as a starting point. I set up a mesh...
My setup is a custom board with a nrf5340 which acts as the BLE Central and SDK 2.6.99. When I use a 52833 DK as the peripheral which has the BAS service I can connect and...
