I have a custom board and using an external LTE antenna. Please assist me with the configurations to connect to the internet. I once connected with the following but...
I have read some of the Asset Tracker documentation and noticed there is a nice implementation for operating LEDs in the UI module. This seems straightforward for GPIO control...
Hi
at embedded world nordic presented a camera demo similar to this:
https://www.youtube.com/watch?v=mkYzTxRO1-w
Where can I find the repo for that (app and firmware...
I've got a product where a GATT server runs on an nRF52832, based on nRF52 SDK (15.x)
It relies on notifications. The client connects, enables notifications, and can then...
I am using the GUI app.overlay program to modify the pin locations. I changed the UART0 pins to be P0.00 to P0.03 (from P0.05 to P0.08) so I could free up the default pin...
Hi
I struggle with my external QSPI flash and power consumption of our custom board (at least I think that would be the problem with too high idle power consumption)....
I am in the process of making a custom service for a peripheral I am developing. I have some data that I would like to have in the same characteristic because it will be retrieved...
This is my first time taking a crack at embedded wifi, and I'm currently creating multiple wireless devices to pair with a usb dongle. The Antenna prototype is being...
Hi
Hello Devzone Community,
I try to redo the CRC check of an incoming IEEE 802.15.4 frame in software after manipulating certain positions.
Since the check of the Frame...
Am Implementing Zigbee on NRF52840 chip with help of VS Code.
Zigbee Stack : 2.5.2
I configured nrf52840 DK as Zigbee network coordinator and another custom made...
I am migrating one of Segger Embedded Studio based project to NRF Connect SDK for nrf53 series of board.
I migrated the function that uses GPIOTE feature using relevant...
I'm trying to merge together a couple of sample projects to make a prototype (in particular, the LTE-BLE gateway, and AWS-IoT samples) - to run on the nRF 9160DK...
Designing a board with limited space (35-40mm) and need a chip antenna recommendation for the RF transceiver.
Anyone have experience with the Johnson Technology 2450AT18B100...
I have a device that runs NCS 2.0.2 on an nrf5340 and have an occasional issue with service discovery.
I have recently found that after calling sys_reboot() on my device...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
Hello.
I bought an nRF5340 DK board and am trying to run the HRM example (which uses the ANT+ protocol) on it. The standard (create a new application -> copy a sample) blinky...
I am having problems connecting to LTE and AWS.
We had consultants developing the prototype code, and it worked perfectly on our 3 first hardware revisions (custom product...
I am working on nRF52833 IC for my application and implemented my code on the nRF52833-DK and tested. Now we designed our custom board as per our project requirements...
