Is there any strategy/method or example of how to perform (non Nordic) MCU to (non Nordic) MCU firmware update via UART ? We want the non Nordic chip to do the firmware...
We are currently working with Zigbee coordinator sample SDK version 2.1.0. When attempting to write data to a unavailable device, the stack sends an unimplemented signal four...
Hi Team,
Can you please tell the AT commands of below.
1. AT command to keep nRF9160 in sleep mode.
2. AT command to wakeup nRF9160.
Sravan Rikka
We are trying to Perform DFU to nrf52840 from ESP32.Is there any Master DFU Code in the nrf SDK so that we can port this code to ESP32 IDF and perform DFU from ESP32...
Our product need CE approval. For that the radio must be set into an active transmitting mode among other. I have read the radio_test example is a good option.
To get a...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
how to convert/format NCELL data to data that you can use to find the cell on a cellmapper.
This is a ncell result: %NCELLMEAS: 0, “06223A0C”, “20610”, “5334”,65535...
Im using nRF Connect for VSCode on a Mac, creating a new application from any of the Matter samples works great with SDK 2.5.2.
However when using SDK 2.6.0 again creating...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
My device is failing to initialize because of an error with fds_init(). I am using SDK 14.2 with NRF52840.
It seems like the same problem as here , except no answer...
Hi, I'm working on a project with a custom board using a nRF52840. We are working with SDK 15.3
I have to setup the board for CE certification using the DTM example, adapted...
Hi, I try to connect ble devices to my iphone. I can send hid data over bluetooth but virtual keypad is hiding. I cant open it. I tried to send 0x65 data as hid report but...
Hi
I'm using nrf toolchain/sdk 2.5.2.
Got a strange problem with my QSPI NOR flash interface. when i run flash_erase i get error message "qspi_nor: Failed to schedule...
Hello everyone! I'm trying to implement the usage of accelerometer LIS3DH on a custom board. My board has nRF52832 microcontroller as the brain and a few ICs for different...
So, my issue is weird. Just followed SDK course, installed everything as described, setup, all good, working, updating board etc, couple time freezed but recovered...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
In nrf5340 pin assignment for SPIM2 is given,
How to select which pin to use if we need to use SPIM1/3?
How to know Pin function and all its alternate functions...
I am trying to program MS12SF1 module through nrf5340DK. I tested the blinky code to toggle the LED pins but while checking through oscilloscope the pins showed nothing, wasn...
I'm working on an application where we're implementing the nPM1300 and utilizing the fuel gauge algorithm to estimate battery life. Interestingly, the results that...
Is there a call back for config server for ble mesh?
Lets say, when relay mode is set, I can bring that out in a callback to do something?
if a key is bound to...
