Hi ,
I'm Using nRFconnect SDKV2.3.0 and in the central device i'm jus trying to read RSSI in connnection Callback but it's always reads as 127.
These are my configurations...
In nrf5340 pin assignment for SPIM2 is given,
How to select which pin to use if we need to use SPIM1/3?
How to know Pin function and all its alternate functions...
Hi Everyone,
I am using NRF52833 QFN-40 Package. As I know in datasheet, they have mentioned two I2C Channel is available. I am just curious is for all packages of NRF52833...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
Hello, Karl Ylvisaker. When I use 52840 scan, I sometimes fail to scan other Bluetooth devices for a long time, but the scan will resume after a long time. Other Bluetooth...
hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
I have DK of nRF5340, I want to get started with it and create the development env, as well as I need to measure the sleep current for this module?
Any quick tutorial which...
Hello There are multiple tickets regarding this but I could not find the one that specifically handles my case
In my case when MCUboot is enable the flash is overflowed...
I have the logging module activated with two backends UART and RTT. The SHELL module is using UART. I'm trying to control the SHELL UART logging backend at runtime,...
I am currently working on a project involving the nRF5340 Audio Development Kit, and I am facing issues while trying to build the DMIC sample provided in the Zephyr RTOS https...
Hello.
I'm developing some kind of wearable device with using nRF52832.
I'm using Segger Embedded Studio for developing.
I write my code by modifying ble_app_template...
Dear Support team,
Project information :
Hardware : nRF5340 Custom Board
SDK : nRF Connect SDK v2.2.0
I have integrated watchdog timer to my project. I've used...
i use the nrf52833dk with ncs 2.6.0 and the official peripheral_uart example to test NUS. When i use my new Galaxy Tab A8 (Android14) and try to connect to the board...
Am Implementing Zigbee on NRF52840 chip with help of VS Code.
Zigbee Stack : 2.5.2
I configured nrf52840 DK as Zigbee network coordinator and another custom made...
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance...
I'm attempting to generate a binary blob containing both the S140 SoftDevice (to be placed at address 0x1000 in flash) and the main application firmware (at 0x26000).
I...
I am using PCA10056 for external debugging. When I connected PCA10056 to the external NRF52840 module board for debugging and then transferred it to another module,...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
