What are the parameters affecting the Thread network range other than the TX power ?
I am using Micromod nRF52840 module , to test Matter Light Bulb and Matter...
I have a custom board using 2 fanstel modules one for the nrf5340 and one for the nrf7002. I am having an issue where about half the boards stop scanning at the exact same...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
I would like to implement a simple USB HID Keyboard application on nRF52840 or nRF5340, where a button press on the dev kit sends an HID key over USB. I am using...
Hi
I easily got my FW update running using tutorial:
https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-bootloaders-and-dfu-fota/topic...
I believe that the Nordic fork of hostap ( https://github.com/nrfconnect/sdk-hostap ) has a bug in os.h:
typedef uint64_t os_time_t;
The upstream has that defined as long...
Hi all, i have some problem while i try to estabilish an LTE connection . I'm using nordic n9160dk. I just search through the site, and i see a lot of topic like this , or...
I didn't find any information about the Gain of the Onboard PCB Antenna of the Developement Kit, nor the effective Transmit power that is available. Where can I find it, and...
Hello.
I bought an nRF5340 DK board and am trying to run the HRM example (which uses the ANT+ protocol) on it. The standard (create a new application -> copy a sample) blinky...
I am looking into relay nodes and my nodes do not seem to relay,
All nodes are provisioned with the same provisioner and have the same keys
The following configs...
Request
I need help debugging to figure out why I'm getting the infamous ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0 Any ideas on what I should investigate next would be...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
I'm trying to use the Observer example in zephr-sdk-0.16.5 to work with beacons that only use long range coded phy mode. I've updaed prj.conf to take what I believe to be...
I am in the process of making a custom service for a peripheral I am developing. I have some data that I would like to have in the same characteristic because it will be retrieved...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
I was wondering if there is away to perform DFU using SPI without smp protocol or mcumgr from one nRF52840 to another? What I am trying to do is to send a firmware...
Hi
