For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
Due to the increase in functionality, the amount of new application code has increased. After DFU operation, FDS Init failed to restart. However, if I use the complete hexadecimal...
Hi, I try to connect ble devices to my iphone. I can send hid data over bluetooth but virtual keypad is hiding. I cant open it. I tried to send 0x65 data as hid report but...
I am using the nRF9160 aws_iot sample. I was now trying somethings that are not optimal situations.
For example, I made some FIFO buffer to write in measurements in one...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
I am working on a project that requires my MCU to have a sleep and awake cycle. I have noticed that when my MCU sleeps (by using k_sleep() in threads) the UART peripheral...
i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
I'm looking to create a custom board with MDBT50Q-1MV2. Can I directly power it from a LiPo battery (3.7V - 200mAh) only to the VDDH pin? My board is very compact, so I want...
I want to program a nRF52840 as RELAY NODE.
If I set CONFIG_BT_MESH_RELAY=n in prj.conf, with nRF Mesh app on my smartphone I see that Relay feature of the node is...
I am using the latest version (v4.0.4) of the app Bluetooth Low Energy when I select the device the page loads for about 1s and then the page gets white again. I also tried...
Dear Support team,
I'm involved in the activity to migrate to NCS a project already developed & successfuly tested with using nRF52 SDK v17.1.0, over the custom board initially...
I am working on a custom PCB that involves the NRF5340 and our first iteration of PCBs had soldering issues during assembly for the nRF5340. The nRF5340’s footprint...
We are working with nRF5340 with SDK v2.5.2.
Each time we try to program the board, we get below error.
We do not see this error if we try Erase and Flash option...
Hi! I'm currently developing a project that uses mcuboot. For some evaluation purposes, I'm testing stuff on nrf5480dk and today I came across a strange error. After flashing...
I'm encountering persistent address conflict issues within my Nordic project.
Occasionally, when a device joins the network, I observe address conflict errors....
I have a question regarding automating the download process of certificates and software for mass production apllications that need to communicate with an AWS cloud...
Hello, I am currently working on nrf52840 using nrf-sdk v2.2. to build a Matter firmware. I encountered an issue that a small number of chips UART received data incorrectly...
for a development project I need to make a USB device HID. I started from the example project: \v2.6.0\zephyr\samples\subsys\usb\hid so on version 2.6.0 of zephyr...
I am using Micromod nRF52840 module on the ATP Board to test Matter Light Switch and Matter Light Bulb and I got poor network signal
I successfully can communicate...
