Abnormal power consumption is observed after using sd_temp_get to retrieve the MCU temperature on the nrf52840.
**SDK Ver: SDK17
**Source Code:
temperature.c
float...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
I have a SIM card that connects via MQTT from an nrf9160 to a server. (using mqtt sample)
The cell search is slow, but once it connects (after a long time), it stays...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
Hi, I am using nrf52840dk along with Quectel BG95 module with the sample "cellular modem"
Can i able to use the bg95 driver for nrf52840??
When i tried to build it for...
I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
**SDK Ver: SDK17
**Source Code:
temperature.c
float...
I connected one external BH1749 sensor with nrf5340DK and was testing it with the bh1749 sample code but the sensor is only getting initialized and I am getting [00:00:00...
I'm having problem with SPI devices using nRF Connect SDK 2.6 with a 9160DK. Following lesson 5 in the intermediate course I get BUS FAULTS when the application starts.
I have the logging module activated with two backends UART and RTT. The SHELL module is using UART. I'm trying to control the SHELL UART logging backend at runtime,...
Hi, I recently installed the last version of the SDK v2.5.2 and when I try to build the sample direction_finding_central I am getting the following error
I am running...
I have discovered a bug in the fota_download.c file contained in the SDK. I am attempting to cancel the FOTA update separately within my application code, and it goes...
I am not sure what happened. I started with the main branch of ncs-example-application and I was able to build it. I then noticed it wasn't 2.3.0 so I instead checked that...
We need to do some crypto. The first task being to generate a random number with rng. I have been fighting through the sdk_config.h defines, and the list of modules that need...
I've been following the steps indicated by the " nRF_Sniffer_BLE_UG_v4.1.x" document in order to set up my nRF52840 dongle as a BLE sniffer for Wireshark. Unfortunately...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
Hi
I struggle with my external QSPI flash and power consumption of our custom board (at least I think that would be the problem with too high idle power consumption)....
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
Is there a call back for config server for ble mesh?
Lets say, when relay mode is set, I can bring that out in a callback to do something?
if a key is bound to...
hey! So i require some guidance regarding the implementation of system ON low power mode in my sdk. 1. I have configured interrupts for all button press, so that the interrupt...
