1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
I am trying to use a 10-pin flat cable to connect my custom board to nRF52-DK to program the nRF52840 on my custom board.
Just wanted to make sure I connected...
Hi i am trying to get fw encryption to work for my dfu with mcuboot for nRF9160DK.
I have created a child_image folder with a mcuboot.conf where i have put:
and then...
I have a question regarding automating the download process of certificates and software for mass production apllications that need to communicate with an AWS cloud...
We want to use a nrf52840 as a logic controller which reads data from Modbus RTU Sensors (as Modbus RTU Master) and simultaneously is the Modbus RTU Server for an...
Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
Hello We have nrf5340 min development kits. I am trying to compile the periphal_Ibs example in SDK 2.5.2 and throw it into application and network cores. While I can upload...
Hi, I need help with these tasks in Lesson 2 ex 2 (step 7. and 8.)
Looking for that path and python file everywhere, unable to find it, I don't have zephyr folder, none...
Hi, I recently installed the last version of the SDK v2.5.2 and when I try to build the sample direction_finding_central I am getting the following error
I am running...
Hello, I have a problem with PCA10028 DK Board. When i connect the board over usb to pc, the board is defined by pc. But i can not flashing. When i measure the voltage circuit...
Hi Support Team,
I want to store sensor-monitored data per minute into the QSPI flash(mx25r6435f) on the nRF5340 DK, and send these data over LTE/mqtt per day. Could you...
I'm encountering persistent address conflict issues within my Nordic project.
Occasionally, when a device joins the network, I observe address conflict errors....
Hi, I am new to PCB design, so I want suggestions for my designed PCB. Please review it once and provide feedback upon that. I am making this PCB to use this with Thread and...
Hi.
I want to modify the "nPM1300 One Button" example.
I need the Ship mode to be activated after pressing and holding the SHPHLD button for longer than 3 seconds. The...
I am recently trying to get up and running with the nrf9160-DK and have been unable to flash the board successfully even with the Quick start (v0.2.6) app in nrf Connect....
I have found that nrf5340 support the usb device function. It can be used for sound card which can receive the audio signal from the PC, and output the mic signal to PC. ...
I'm using a Windows 11 IBM computer. I have gone thru the Dev Academy exercise 1. I installed the software's, nRf for Desktop, nRF Connect SDK, its toolchain, VS Code IDE...
OS: Ubuntu 20.04.6 NCS SDK: 1.6.1 Segger: 5.50c
I recently got a new laptop, which I installed using the following guide:
https://developer.nordicsemi.com/nRF_Connect_SDK...
Power-on reset will require pairing again.
I found this happening by doing bt_id_reset().
Is there a problem with the way the BD address is initialized?
How to initialize...
Good Day!
Can you please tell me if nRF52 microcontrollers are well suited for creating a cold cryptocurrency wallet based on them?
Do you have libraries, APIs or any...
Hi guys:
Right now I have my custom board using nRF52833.
I wang to use DFU over uart to upgrade firmware.
I try a different way to enter DFU mode, and this require...
There was no problem when using the circuit below in the previous circuit,
After removing the USB part and changing the circuit as shown above, the input is that the CHG...
