I am using nRF52832 board and I want to understand the current consumption in the board will differs while running the code in zephyr RTOS platform and without zephyr...
I'm on a research to find out how I can use synchronization feature only from LTE for other Wireless Sensor Network.
In online profiler page, There's no explanation about...
I would like to put mcuboot in external NOR flash storage for saving internal nRF5340 flash storage. Does Nordic provide sample code for putting mcuboot in external NOR flash...
1. How do I add http User-Agent in example ncs v2.6.0 application_update? 2. Does the client's server reject User-Agent? Incorrect nRF9160 device connection.
Thank...
Running an nRF52840DK on the zigbee light switch multiprotocol ble sample as a sleepy end device seems to get stuck in the zboss thread. In this state the devkit seems to...
I've made a dongle using the nrf52840, and I'd like this custom device to work with the RSSI Viewer and Bluetooth Low Energy on nRF Connect for desktop; what do I need to...
ncs 2.6.0
I'm encountering a weird bus data error when I'm calling psa_generate_random inside a work queue thread (it has name "api"):
The code I'm running...
I am using the I2S slave mode in my nrf52840 based board (seeed studio xiao), I am confused regarding the I2S interface. I actually opened another ticket but nobody seems...
I have a custom device with a nrf52840, a a01nyub with uart bus, a pt1000 with SAADC. I succed to have in advertising just 10-20 µa and also in connexion, but after...
hi support team,
customer is developing ble and usb mouse project using sdk17.1.0. and now we have met problem about ble mouse movement.
so i simulate it using our demo...
To synchronize user programs and advertisement, I need to know when the BLE event will end, I hope when the event end, it will notify application(user logic), Is there a relevant...
We are using the nrf5340 audio demo, and the audio delay currently tested in BIS mode is about 40ms. We are trying to achieve lower transmission latency, without considering...
Thank...
I am developing with nRF5340 because I want to use nRF7002. When I try to use extended advertisements or extended scanning, I get error -5 (EIO). Why is this?
It automatically...
1. The customer needs to use opus-1.4 library on nRF9160 2. Please tell me the instructions for compiling opus-1.4 into the lib library 3. It would be better if there...
1. I added an at instruction to the example serial_lte_modem to connect to the nRF Cloud but it always fails. What can I do?
2. The code is as follows:
3. Connection...
Hi ,
I have a little difficulty in using the .a .
I added the following syntax, but this .a was not added in the compilation.Even reported it wrong.
I need to know...
