Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
Hello We have nrf5340 min development kits. I am trying to compile the periphal_Ibs example in SDK 2.5.2 and throw it into application and network cores. While I can upload...
Good Day!
Can you please tell me if nRF52 microcontrollers are well suited for creating a cold cryptocurrency wallet based on them?
Do you have libraries, APIs or any...
I'm encountering an issue with the Matter template code in nRF Connect SDK v2.6.0 on my custom board. Strangely, the same code runs perfectly fine on my board when using the...
I've stumbled upon an adc_read issue on NRF52832, where following a certain sequence, adc_read gets stuck forever. I'm inserting a small code block that replicates the...
Hi there
I'm working on nRF5340 chip and looking for a way to preserve the factory data that is saved in factory_data region. I tried playing around with the factory data...
Hi,Nodic!
We are now using nrf5340, ncs2.5.0 to do the project.
We are using disk mass storage with a filesystem mounted on an external memory device.Now I see that this...
Hello, I'm trying to use MCUBOOT with external flash on a nRF52840 board that has 4MB SPI flash. I'm using nRF Connect SDK v2.6.0. I've verified that the SPI flash works fine...
Good Day!
We have been using SDK version 2.1.1 and currently are in the process of migrating to SDK version 2.5.0.
Would be helpful to get some hint regarding what conditions...
NRF_ERROR_FORBIDDEN
Forbidden value supplied, certain UUIDs are reserved for the stack.
I was developing a new sw in demo board. I have added some new services and...
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
I'm starting to be fustrate with nrf9160 evaluation as it seems nothing works in our environment.
We have had a lot of issue to run SPI (not running yet) but as we are in...
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via...
I'm trying to develop a Zigbee application for the Seeed Xiao nRF52840 BLE board.
I can compile the "Blinky" demo app in nRF Connect for VS Code and run it on the board...
Hi there
Hi,Nodic!
I believe that when the nRF5340 operates in LE-Audio CIS mode, the Gateway and Headset are connected, but where is the bonding information set in the source?
