My setup is a nRF7002-EK shield on top of the nRF9160-DK. Trying to use this shield to connect to a Wi-Fi network, using the shell example compiled with the suggested command...
I'm having problem with SPI devices using nRF Connect SDK 2.6 with a 9160DK. Following lesson 5 in the intermediate course I get BUS FAULTS when the application starts.
I've been trying to get MCUboot to work with Direct XIP for several days but each time I have a compilation problem:
In fact, I would like to have a project...
Hi,I'm develop with the nRF52840 V17.0.2 ,SD 7.2.0
problem about migrate LVGL 8.1
I have few app_timer ,they are work fine
try to migrate LVGL
alfter lv_init(), app_timer...
I am try to connect AWS IoT MQTT using nRF7002DK. I followed the below link.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/networking/aws_iot...
Hello DevZone,
I'm trying to run Matter over Thread demo on nRF7002DK. In fact, it's not a real 7002DK, but a simplified version. You can check the documents about this...
Hello, support team:
Environment describe: nrf52840,NCS v2.4.0;
I am developint on nrf52840 with openthread.One of the device is thread Leader and others as thread EndDevice...
hi professor,
The npm1300 is used for power management on my borad.When VBAT and VBUS are connected simultaneously, the bulk 2 output power supply varies between 1V and...
Good afternoon.
I have asked for help before regarding my nRF52840 Dongle and Ant+ and you have helped me a lot! But I have one more difficulty - I have an error when initializing...
I am working on a Mac mini, Apple M2 chipset, macOS Sonoma 14.2.1. I am using Visual Studio Code Version: 1.86.2 (Universal) Commit: 903b1e9d8990623e3d7da1df3d33db3e42d80eda...
Just upgraded to NRF v 2.6.0 (Mac OS; VS Code). Our code previous built and ran successfully on our custom board with v 2.5.0 of the SDK.
Now we get the following error...
We are developing an application that will download an application update image over cellular HTTP. We want to skip the DFU transport altogether and directly write the image...
ncs 2.6.0
I'm encountering a weird bus data error when I'm calling psa_generate_random inside a work queue thread (it has name "api"):
The code I'm running...
I built the littlefs zephyr example found in "/zephyr/samples/subsys/fs/littlefs"and then modified it to use the external flash "MX25R64" by adding an app.overlay file. I...
We are evaluating a pedal power meter for bicycle, but have a question we would like some advice.
Usually pedal-type power meters are divided into left and right sides...
I am using nRF52832 board and I want to understand the current consumption in the board will differs while running the code in zephyr RTOS platform and without zephyr...
I'm on a research to find out how I can use synchronization feature only from LTE for other Wireless Sensor Network.
In online profiler page, There's no explanation about...
Hi, I am currently working with the nRF9160DK board, using SDK version 2.5.1, and I have encountered an issue regarding connectivity to the AWS IoT cloud.
I have successfully...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
Hi Team,
I'm using nrf9160. I'm trying to connect to the network by using the nrf9160 controller with in built modem. I'm getting the error code -14 and modem not initialized...
