We are currently working with Zigbee coordinator sample SDK version 2.1.0. When attempting to write data to a unavailable device, the stack sends an unimplemented signal four...
Hi Team,
Can you please tell the AT commands of below.
1. AT command to keep nRF9160 in sleep mode.
2. AT command to wakeup nRF9160.
Sravan Rikka
We are trying to Perform DFU to nrf52840 from ESP32.Is there any Master DFU Code in the nrf SDK so that we can port this code to ESP32 IDF and perform DFU from ESP32...
how to convert/format NCELL data to data that you can use to find the cell on a cellmapper.
This is a ncell result: %NCELLMEAS: 0, “06223A0C”, “20610”, “5334”,65535...
Our product need CE approval. For that the radio must be set into an active transmitting mode among other. I have read the radio_test example is a good option.
To get a...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
When including RNG configuration I am getting the error: Warning[Li026]: the module "sns_silib.c.obj(libnrf_cc310_0.9.13.a)" (and 15 other modules) do not contain information...
I used this guide to add FOTA over BLE for nRF5340.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/device_guides/working_with_nrf/nrf53/nrf5340...
In nrf5340 pin assignment for SPIM2 is given,
How to select which pin to use if we need to use SPIM1/3?
How to know Pin function and all its alternate functions...
I'm working on an application where we're implementing the nPM1300 and utilizing the fuel gauge algorithm to estimate battery life. Interestingly, the results that...
I am using nrf52832 as a peripheral and running SD S112, nordic UART Profile and SDK 17.1.0 on it.
After I start advertisement with the manufacturing data, I...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
hi
I am configuring a product using nRF52832 and NUS.
This time, I'm trying to view BLE wireless data (raw) from central and peripheral, but I can't find a way to do...
Hi all,
I have a SPIS implementation on an nRF52840 running smoothly. Recently I'v had the need to receive large packets (up to 270 bytes) in one single transaction. However...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
I have a nRF9160DK board that is used for development of a custom nRF9160 board. The hardware designers have assigned GPIO P0.27 to be a general purpose output pin. This pin...
We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using...
In working thru the Nordic Academy Intermediate lessons on DFU, it was very instructive to use the mcumgr command line interface to see exactly what's happening on the device...
hey! So i require some guidance regarding the implementation of system ON low power mode in my sdk. 1. I have configured interrupts for all button press, so that the interrupt...
I have a custom board and using an external LTE antenna. Please assist me with the configurations to connect to the internet. I once connected with the following but...
