I have discovered a bug in the fota_download.c file contained in the SDK. I am attempting to cancel the FOTA update separately within my application code, and it goes...
Hello thats my code
and for a 2 days im completely stuck with reading data from LIS3DH, i guess my functions for writing and reading are fine. my read buff is just uint8_t...
Hi, I am working with the nrf9160 and need to get the current date / time. It looks like overall this is pretty simple to do, but I had a question about local time. Using...
I am using Micromod nRF52840 module on the ATP Board to test Matter Light Switch and Matter Light Bulb and I got poor network signal
I successfully can communicate...
I am using a nRF5340 with mcuboot and multiple customer-specific partitions. I did not finish creating a separate board definition yet. Currently, we are using the...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
Hi! I'm currently developing a project that uses mcuboot. For some evaluation purposes, I'm testing stuff on nrf5480dk and today I came across a strange error. After flashing...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
I have an old nRF9160DK from few years back (v0.8.2). I got busy with other things and was not able to work on it.
Now I'm trying to update the modem firmware to the...
Hi Nordic
It has not be found much in Nordic documentation about sniffing/monitoring over-the-air communication of Matter.
Any recommendations are appreciated.
Or, would...
I'm getting timeout errors when trying to program a Thingy:91 with a J-Link Pro PoE on macOS on an ARM Apple M3 Max.
Here's the command and error message:
I get the...
I am writing to seek assistance with an issue I've encountered while attempting to create a modem trace on my nRF9160DK board.
When flashing my asset tracking code...
The Central device is using Resolvable Private Addresses.
Even though private_addr_cycle_s is set to BLE_GAP_DEFAULT_PRIVATE_ADDR_CYCLE_INTERVAL_S (15 minutes),
When observed...
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in...
I am using nRF Connect SDK V2.3.0. How can I power down the UART?
I am using the Interrupt-driven UART API, interrupt driven on RX and polling on TX. I have disabled...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
I have a nrf5340 board which I'm trying to finalize the bootloader process on.
From what I understand, the TF-M architecture uses a secure bootloader version of MCUBoot...
Hi, I am new to PCB design, so I want suggestions for my designed PCB. Please review it once and provide feedback upon that. I am making this PCB to use this with Thread and...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I'm encountering an issue with the Matter template code in nRF Connect SDK v2.6.0 on my custom board. Strangely, the same code runs perfectly fine on my board when using the...
Hello, we have a product that uses the NRF52832. We recently detected that the device will randomly increase its current consumption by about 260uA during sleep mode. Once...
