Hi Team,
Can you please tell the AT commands of below.
1. AT command to keep nRF9160 in sleep mode.
2. AT command to wakeup nRF9160.
Sravan Rikka
We are trying to Perform DFU to nrf52840 from ESP32.Is there any Master DFU Code in the nrf SDK so that we can port this code to ESP32 IDF and perform DFU from ESP32...
how to convert/format NCELL data to data that you can use to find the cell on a cellmapper.
This is a ncell result: %NCELLMEAS: 0, “06223A0C”, “20610”, “5334”,65535...
Our product need CE approval. For that the radio must be set into an active transmitting mode among other. I have read the radio_test example is a good option.
To get a...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
Dear Support Team,
Hardware : nRF5340 Custom board
Software : nRF Connect SDK v2.2.0
I have implemented OTA FW update for nRF5340. I've used multi-image simultaneous...
Hi there,
I'm using an nRF52840 pin to monitor GPIO state transitions, but it keeps reporting frequent phantom low transitions without high transitions in between. According...
I'm trying to use the Observer example in zephr-sdk-0.16.5 to work with beacons that only use long range coded phy mode. I've updaed prj.conf to take what I believe to be...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in...
I trying to generate dfu images following the procedure described below:
https://novelbits.io/nrf52-ota-dfu-ble-part-4/
the procedure to generate files is ok,...
Hi ,
I'm Using nRFconnect SDKV2.3.0 and in the central device i'm jus trying to read RSSI in connnection Callback but it's always reads as 127.
These are my configurations...
I'm developing my application using the NRF Connect SDK in VS code. SDK Version 2.4.2. The NRF52832f we're using is integrated into a module made by fanstel and it has been...
Hi guys!
Right now I have my custom board which used nRF52833 SoC. There is only one reset button on custom board and dfu performed via uart.
I flashed four hex file ...
Hi Team,
Sravan Rikka
Hello everyone! I'm trying to implement the usage of accelerometer LIS3DH on a custom board. My board has nRF52832 microcontroller as the brain and a few ICs for different...
Unable to use uart ,I2c,SPI together as shown in the error message. I am attaching the dts overlay file
Is there any way to use all UART,SPI,I2C together. Please let me...
We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
