I am dealing with a persistent I2S RX overrun issue in the nRF5340 audio application that is impacting data reception and disrupting communications between the gateway...
Hi Support Team,
I'm using nRF5340-DK and the netCore was used for the BLE controller only, the appCore was used for the BLE host and my application.
The below cmake arguments...
I want to program a nRF52840 as RELAY NODE.
If I set CONFIG_BT_MESH_RELAY=n in prj.conf, with nRF Mesh app on my smartphone I see that Relay feature of the node is...
I am using the latest version (v4.0.4) of the app Bluetooth Low Energy when I select the device the page loads for about 1s and then the page gets white again. I also tried...
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
Hello! We recently acquired a Nordic Thingy:91 for prototyping and it was working great until I came into work this morning and it was no longer showing any signs of life...
Hello, there seem to be a lot of technical details missing from the datasheet. In my case, I really need to know the capabilities of the load switches such as reverse current...
Hi there
I'm working on nRF5340 chip and looking for a way to preserve the factory data that is saved in factory_data region. I tried playing around with the factory data...
Hi everyone, i am developing a bluetooth scanner device using nrf52833 and using the "ble_app_uart_c and softdevice:122" example as software. I am reading scanning data in...
Accidentally used a 9V power supply. Board does not flash anymore.
Can still connect to com ports, and onboard led lights up.
Is the board fried or is it stuck in a memory...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
Hello, I have a custom board containing a module from Raytac with a Nordic nRF52840 microcontroller on it. The board also has a 32768kHz oscillator connected to the module...
I am trying to DTM(direct mode test) for nrf 52832 chip.
I compiled and flashed the DTM code from NRF official(SDK V2.6.0),But when i open the NRF DTM desktop app ,the app...
I followed this example to enable I2C for my sensor: https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-6-serial-com-i2c/topic/exercise-1-6...
What is going on here?
I'm trying to get the central_uart example to run on the xiao ble sense nrf52840 board but uart_init() fails when trying to set the callback:
My setup is a custom board with a nrf5340 which acts as the BLE Central and SDK 2.6.99. When I use a 52833 DK as the peripheral which has the BAS service I can connect and...
We're developing an LwM2M application based on the lwm2m client sample with the goal of sending data to ThingsBoard as our main telemetry platform.
The Application in based...
I am working on a custom PCB that involves the NRF5340 and our first iteration of PCBs had soldering issues during assembly for the nRF5340. The nRF5340’s footprint...
Dear support team,
1. Can mesh provisioner configure multiple devices at one time? For example, there are five unprovisioned devices within the provisioner's network. Can...
new to nordic and keil need help compiling custom project
currently my main file only works with the nordic 1822 series processor and in your example.
I need to have it...
