Dear Support team,
Project information :
Hardware : nRF5340 Custom Board
SDK : nRF Connect SDK v2.2.0
I have integrated watchdog timer to my project. I've used...
Hi Everyone,
I am using NRF52833 QFN-40 Package. As I know in datasheet, they have mentioned two I2C Channel is available. I am just curious is for all packages of NRF52833...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
Hello, Karl Ylvisaker. When I use 52840 scan, I sometimes fail to scan other Bluetooth devices for a long time, but the scan will resume after a long time. Other Bluetooth...
hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
I would like to be able to dynamically enable & disable APPROTECT from a zephyr application at runtime, not via Kconfig. Is there existing driver support for this feature...
Dear Support team,
I am using PCA10056 for external debugging. When I connected PCA10056 to the external NRF52840 module board for debugging and then transferred it to another module,...
Hi Everyone,
I tried implementing a PDM interface for recording sound from a microphone on the nrf52840. For this purpose, I used the official example which is accessible at github.com...
Hello Nordic support, I work on receive data from the microphone mp34dt05-a . I have some question. 1- How to enable PDM in SDK_CONFIG.H . 2- For this project do I need enable...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
I'm attempting to generate a binary blob containing both the S140 SoftDevice (to be placed at address 0x1000 in flash) and the main application firmware (at 0x26000).
I...
hi,I am using the NRF52840, softdevice: s140,
If a Bluetooth host simultaneously connects to multiple Bluetooth peripherals, and the peripherals transmit data to the host...
hello,
I made a development board using the nrf52840 module.
What methods are there to measure power consumption?
I know of two methods: measuring with the Power Profiler...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
I'm using the custom board of nrf 5340 with 7002.
When I run the sample project of Hello World, the current is about 90 ma,
and I run the sample project of WI-FI Scan...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
