NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I'm writing an android application, using no.nordicsemi.android:ble:2.3.1. I connect to the sensor and write 49KB data to it. Before recording, I set the desired interval...
Hello everyone,
I have questions. I am trying to scope 32mhz external clock on osilloscope that gwınstek gds-1062 and I show this two picture. First is at 250ms time/div...
1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
Hi i am trying to get fw encryption to work for my dfu with mcuboot for nRF9160DK.
I have created a child_image folder with a mcuboot.conf where i have put:
and then...
I have a question regarding automating the download process of certificates and software for mass production apllications that need to communicate with an AWS cloud...
We want to use a nrf52840 as a logic controller which reads data from Modbus RTU Sensors (as Modbus RTU Master) and simultaneously is the Modbus RTU Server for an...
I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb' 254 ...
i have a custom board that uses a nrf5340 that has been hardware modified so i can work again on getting my board to draw the mimimum power from the battery.
i have a PPK2...
Hello, it's a bit urgent, I want it as soon as possible. I made a child image for the MCU boot. my problem is, while compiling code it says the undefined reference to "mcuboot_swap_type...
Hi Nordic
It has not be found much in Nordic documentation about sniffing/monitoring over-the-air communication of Matter.
Any recommendations are appreciated.
Or, would...
NCS v2.6.0
nRF52 DK
I am trying to use a 10-pin flat cable to connect my custom board to nRF52-DK to program the nRF52840 on my custom board.
Just wanted to make sure I connected...
I Dried to start on base of ADC sample and using another pin as ADC pin
i fond a tree example
with
zephyr,input-positive = < NRF_ADC_AIN0 >; /* P0.04 */
Using...
Hello everyone,
Hey,
seen again a modem fault, from a device in field, no further debug information available.
nRF9160
Modem FW: 1.3.6
Modem Fault Type: 0x10
Modem Fault PC: 0x9900E...
I am using PCA10056 for external debugging. When I connected PCA10056 to the external NRF52840 module board for debugging and then transferred it to another module,...
hello there was a problem configuring the project.
i want build uart central, peripheral project with rpc_host.
The uart peripheral project built fine with -DCONFIG_BT_RPC_STACK...
Hi, I need help with these tasks in Lesson 2 ex 2 (step 7. and 8.)
Looking for that path and python file everywhere, unable to find it, I don't have zephyr folder, none...
Hi, I recently installed the last version of the SDK v2.5.2 and when I try to build the sample direction_finding_central I am getting the following error
I am running...
