Hello, I'm trying to provision nRF9160 DK in nRF Cloud using https://docs.nordicsemi.com/bundle/nrf-cloud/page/SecurityServices/ProvisioningService/ProvisioningOverview.html...
How do I get the value of the characteristic of the service I created? I try to get it with the following code, but the content pointer returned is NULL.
I have implemented the heartrate on central side which notify the measurement value and that can be read from peripheral , now my dought is that is it possible to implement...
Starting from the AWS IoT sample, I’m having a hard time configuring the connection before calling net_if_up() which abstracts a lot of stuff. I would like to configure...
Dear Nordic Support
Recently I have the issue that the nrf-connect.toolchain.path, set in the VS-Code workspace file, doesn't correctly resolve if predefined VS-Code variables...
Hi Support Team,
I want to use an external flash(2M byte) to store the sensor data in a 'circular overwrite' way. I now tried it with the FCB(Flash Circular Buffer) on nRF5340...
hi,
I want to know how Bluetooth allocates channel resources as a master.
Assuming a Bluetooth master is connected to 8 slaves simultaneously, how does the master allocate...
Hi, I was checking the HAL for SPI in master mode and notice that when pm_device_action_run(<spi_device>, PM_DEVICE_ACTION_SUSPEND); the CS pin isnt changed since it status...
Hi
Can I get some idea on which functions to make changes to in order to scan and report(for example on uart) the number of ble devices present in NRF52832 kit range.
I am working on nRF52833 IC for my application and implemented my code on the nRF52833-DK and tested. Now we designed our custom board as per our project requirements...
I didn't find any information about the Gain of the Onboard PCB Antenna of the Developement Kit, nor the effective Transmit power that is available. Where can I find it, and...
I am trying to run the http client on my nrf9160-DK but it is giving me an error below;
*** Booting nRF Connect SDK v2.5.1 *** HTTPS client sample started Bringing...
I'm using the NCS 2.5.2 sdk and nrf 5340 with 7002, and I want to do BLE OTA DFU using external flash.
I've found this guide Add DFU support to your application - Software...
Hi, I am developing matter app controlling RGBW lights/stripe on nRF3540 using nRF SDK. The commissioning of the matter device works fine using Goolge Home (from Android)...
Good afternoon,
I am developing with the nrf connect SDK and I want to implement the Zephyr RTOS in my project. This is cause i have a "main" thread that needs to run...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
Hi all , I 'm using NRF52840DK and I want to use RTT to print logging , but I configured a lot of different configs and I can 't print any information in RTT after all . ...
Hello.
I am developing an SPI FIFO reading program with a accelerometer. with sdk17.1.0
It runs well on nrf52840 devkit but it stuck at nrf52832 devkit.
And I found...
HI,
two years ago I started my adventure with the nRF52840 microcontroller. I started using SEGGER Embedded Studio for ARM as my development IDE. I created a peripheral...
I've been following the steps indicated by the " nRF_Sniffer_BLE_UG_v4.1.x" document in order to set up my nRF52840 dongle as a BLE sniffer for Wireshark. Unfortunately...
Hello, i am having a weird behaviour at a NRF52832 device. To explain. Basically I am using an external RTC chip to source the clock of the LFCLK.
During the initialization...
