Im using nRF Connect for VSCode on a Mac, creating a new application from any of the Matter samples works great with SDK 2.5.2.
However when using SDK 2.6.0 again creating...
I am working on a project where I perform location determination with GNSS and send data over NB-IoT. I have written working code where I am reading location by GNSS...
Hi there,
I'm using an nRF52840 pin to monitor GPIO state transitions, but it keeps reporting frequent phantom low transitions without high transitions in between. According...
i just bought 4 nrf21540db's that I would like to use with Shockburst. My understanding is that the modes, etc are setup through gpio pins, but the power settings are done...
On a nrf52840 (sdk 16.0.0) I have sporadically an unexpected behaviour when I unprovision my device, both with the nRF Mesh and with our custom app. As showed in...
I trying to generate dfu images following the procedure described below:
https://novelbits.io/nrf52-ota-dfu-ble-part-4/
the procedure to generate files is ok,...
Hello to everyone,
I'm pretty in new in developing with Nordic chips and zigbee.
I am evaluating a possible configuration for a Zigbee coordinator and I verified that...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
We are working with nRF21540DK and developing a BLE application. nRF21540DK with nRF Connect SDK 2.5.0 . I have couple of questions.
In nRF21540DB product page says...
Request
I need help debugging to figure out why I'm getting the infamous ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0 Any ideas on what I should investigate next would be...
i use the nrf52833dk with ncs 2.6.0 and the official peripheral_uart example to test NUS. When i use my new Galaxy Tab A8 (Android14) and try to connect to the board...
Hi
I am stuck using a proximus M2M sim card with the AWS-IoT sample. I did get it working with an Ibasis sim card but now I want to use a Proximus M2M sim card but I keep...
I connected one external BH1749 sensor with nrf5340DK and was testing it with the bh1749 sample code but the sensor is only getting initialized and I am getting [00:00:00...
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The...
While using Visual Code I have noticed that:
First compile always generates errors, which is fine. The error notifications are persistent even after they have been fixed...
I want to add some build information (hard coded) into my binary. Is there any way how I can access the current date/time and maybe the revision number of a SVN repository...
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via...
I used this guide to add FOTA over BLE for nRF5340.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/device_guides/working_with_nrf/nrf53/nrf5340...
Hi there,
