Hi, I am developing matter app controlling RGBW lights/stripe on nRF3540 using nRF SDK. The commissioning of the matter device works fine using Goolge Home (from Android)...
How do I get the value of the characteristic of the service I created? I try to get it with the following code, but the content pointer returned is NULL.
I have implemented the heartrate on central side which notify the measurement value and that can be read from peripheral , now my dought is that is it possible to implement...
I have DK of nRF5340, I want to get started with it and create the development env, as well as I need to measure the sleep current for this module?
Any quick tutorial which...
I didn't find any information about the Gain of the Onboard PCB Antenna of the Developement Kit, nor the effective Transmit power that is available. Where can I find it, and...
Hello.
I am developing an SPI FIFO reading program with a accelerometer. with sdk17.1.0
It runs well on nrf52840 devkit but it stuck at nrf52832 devkit.
And I found...
Starting from the AWS IoT sample, I’m having a hard time configuring the connection before calling net_if_up() which abstracts a lot of stuff. I would like to configure...
Hi all,
I am new to the nordic controllers and ANT+ protocol.
And I am going to evaluate ANT+ protocol in nrf52dk board (nRF52832 controller).
I need to understand which...
I've been working on setting up a direction finding tag with the nrf5340dk. I have an AoA locator set up that advertises with ADV_IND packets, and I'd like to setup my tag...
Dear community,
I'm trying to flash a nRF52840 dongle through the SWD interface, but fail. There are already several nRF52840-dongle flashing posts in the forum, but I obviously...
Hello everyone,
I'm working on a Zigbee project that has the Thingy:53 as an end node. The program of the Thingy is a variation of the Zigbee Weather Station .
I'm measuring...
CD Feather9160, Azure IoTHub using DPS. Last part of the console log:
[00:00:06.667,419] <dbg> azure_iot_hub: azure_iot_hub_connect: User name buffer size is 160, actual...
HI,
two years ago I started my adventure with the nRF52840 microcontroller. I started using SEGGER Embedded Studio for ARM as my development IDE. I created a peripheral...
I have two nRF52840 devices one peripheral and one central. Both devices feature the Nordic Uart Service. They are based on ble_app_uart example and e nrf52-ble-app...
Hi Nordic
Sample: asset_tracker_v2 (with only changes to overlay-azure.conf) SDK: 2.5.2 Modem FW: nrf9160_1.3.5
I have followed this tutorial https://learn.microsoft.com...
Dear all, It's my first project with a Nordic chip and with Zepyhr as well, so a little overwhelmed. I made a PCB based on a nRF52840 and the reference design. The custom...
I've a working application on nRF52811 SDK / S140 running BLE. I need to extend it so that from time to time BLE switches off temporarily, to send a simple and short...
