Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
I am interested in creating a Bluetooth application to create a piconet (i.e. multi-link central). I found this sample application that uses the nRF5 SDK rather than...
The PPK2 is always on COM4 on my Windows 11 machine, and I can't seem to change it. I bought a 2nd PPK2, and when I plug them both in, they are both on COM4. There is no ...
Greetings.
This a follow-on to my prior question about the sample app "peripheral_lbs."
The program obtains a value for variable "led_state" in response to a user keystroke...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
Hello I am utilising the nrf5-sdk and have used the ble_peripheral/ble_app_uart example as a reference. I am using a 2MBPS PHY, an ATT MTU of 247, and a connection interval...
I have Micromod nRF52840 module on a carrier board and I've built and flashed Matter Light Switch sample on it but I need to read the logs from the module
How can...
Hi there!
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
Trying to implement FOTA DFU over BLE. My application uses my proprietary code (instead of mcumgr) to download signed OTA firmware image to secondary slot (in my case it is...
Hello, we have a product that uses the NRF52832. We recently detected that the device will randomly increase its current consumption by about 260uA during sleep mode. Once...
I'm trying to setup a simple BLE Advertising beacon the broadcasts once per 3 seconds, th problem Im having is it will do this for about 10 broadcasts then stop and...
Hello All,
I am brand new to ZigBee so I apologize for my ignorance. I am developing a product that will use the nRF5340 for the coordinator, router and end devices (but...
I am using nrfconnectsdk v2.4.0 with zephyr and I have a program with a large number of printk() statements.
is there anything in prj.conf that limits the amount of text...
I'm getting timeout errors when trying to program a Thingy:91 with a J-Link Pro PoE on macOS on an ARM Apple M3 Max.
Here's the command and error message:
I get the...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
Greetings.
