Hi Team,
NCS v2.3.0
nrf52840
my project works as expected with CONFIG_APP_MSC_STORAGE_RAM=y
but I need storage FLASH_FATFS
and the disk does not open in Windows, it gives an error window when connecting nrf USB.
Thank you.
4034.chatDK_update.7z
Hi Team,
NCS v2.3.0
nrf52840
so far nothing has helped.
Serhii
This may or may not be related to your issue, but due to some blocking behavior when working with USB, all shell_print statements in model_handler.c should ideally be either removed or replaced by either printk or LOG.
Regarding the persistent USB storage, I have tested successfully with a following configuration changes applied to your project:
prj.conf
CONFIG_NVS=n CONFIG_SETTINGS=n CONFIG_PM_SINGLE_IMAGE=n # CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000 CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE=n CONFIG_BT_SETTINGS=n CONFIG_APP_MSC_STORAGE_FLASH_FATFS=y #CONFIG_APP_MSC_STORAGE_RAM=y
storage_partition: partition@0 { label = "storage"; #reg = <0x00000000 DT_SIZE_K(8000)>; reg = <0x00000000 0x00020000>; };
Thank you Dejan, I will be satisfied with this option if I can replace shell_print to some kind of uart_tx?
To give out an msg array to the uart.
In version with FOTA and CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
when I add to prj.conf your changes
when I set CONFIG_NVS=n I have error
C:\ncs\v2.3.0\nrf\include\flash_map_pm.h:41:22: error: 'PM_storage_partition_ID' undeclared (first use in this function) 41 | #define PM_ID(label) PM_##label##_ID | ^~~ C:\ncs\v2.3.0\nrf\include\flash_map_pm.h:46:35: note: in expansion of macro 'PM_ID' 46 | #define FIXED_PARTITION_ID(label) PM_ID(label) | ^~~~~ c:\da\ncs\chat\src\mass.c:23:41: note: in expansion of macro 'FIXED_PARTITION_ID' 23 | #define STORAGE_PARTITION_ID FIXED_PARTITION_ID(STORAGE_PARTITION) | ^~~~~~~~~~~~~~~~~~ c:\da\ncs\chat\src\mass.c:34:36: note: in expansion of macro 'STORAGE_PARTITION_ID' 34 | mnt->storage_dev = (void *)STORAGE_PARTITION_ID; | ^~~~~~~~~~~~~~~~~~~~ C:\ncs\v2.3.0\nrf\include\flash_map_pm.h:41:22: note: each undeclared identifier is reported only once for each function it appears in 41 | #define PM_ID(label) PM_##label##_ID | ^~~ C:\ncs\v2.3.0\nrf\include\flash_map_pm.h:46:35: note: in expansion of macro 'PM_ID' 46 | #define FIXED_PARTITION_ID(label) PM_ID(label) | ^~~~~ c:\da\ncs\chat\src\mass.c:23:41: note: in expansion of macro 'FIXED_PARTITION_ID' 23 | #define STORAGE_PARTITION_ID FIXED_PARTITION_ID(STORAGE_PARTITION) | ^~~~~~~~~~~~~~~~~~ c:\da\ncs\chat\src\mass.c:34:36: note: in expansion of macro 'STORAGE_PARTITION_ID' 34 | mnt->storage_dev = (void *)STORAGE_PARTITION_ID;
There might be a problem with coexistence of storage partition with external flash partition. It would be useful if I could reproduce this issue. Could you make a minimal sample which I could use for this purpose?
Dejan
