Error: nrfx_gpiote_input_configure() failed, errCode=0xbad0002
The first calling nrfx_gpiote_input_configure() in afe4900.c is successful. But the second calling nrfx_gpiote_input_configure() in button.c is failed.
What is meaning of errCode=0xbad0002? How can I fix this issue?
00> *** Booting Zephyr OS build v3.2.99-ncs2 ***
00> Starting button Test example
00> configure AFE4900_RDY pin as input
00> configure AFE4900_RESET pin as output
00> configure POWER_UP pin as output
00> configure LED_G pin as output
00> set POWER_UP pin
00> clear AFE4900_RESET pin, 0
00> set AFE4900_RESET pin
00> I2C: Device is ready.
00> 0x39 0x35 0x50
00> device_is_ready() ok
00> btInit() e
00> bt_passkey_set(123456)
00> _btReady(0) e
00> Bluetooth initialized
00> _btReady(0) x
00> btInit() x
00> Error: nrfx_gpiote_input_configure() failed for button, errCode=0xbad0002
  • 1. line number 117 of button.c. I don't use debugger and I just use printk() to print error message.
    2. It still return this error.
    3. Why I got NRFX_ERROR_NO_MEM error with CONFIG_DEBUG=y but no NRFX_ERROR_NO_MEM error with CONFIG_DEBUG=n?   The source code are same for CONFIG_DEBUG=y and CONFIG_DEBUG=n.
     * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <inttypes.h>
    #include <nrfx_gpiote.h>
    #include <zephyr/device.h>
    #include <zephyr/kernel.h>
    #include <zephyr/sys/util.h>
    #include "button.h"
    #include "error.h"
    #include "led.h"
    #include "localtime.h"
    #include "nrf52832_board.h"
    #include "pwr_mgmt.h"
    #define BUTTON_TIMER_MSEC 10000
     * Get configuration from the devicetree alias. This is mandatory.
    #define BOOT_BUTTON_NODE DT_ALIAS(sw0)
    #if !DT_NODE_HAS_STATUS(BOOT_BUTTON_NODE, okay)
    #error "Unsupported board: mcuboot-button0 devicetree alias is not defined"
    LOG_MODULE_REGISTER(button);
     * Helper macro for initializing a gpio_dt_spec from the devicetree
     * with fallback values when the nodes are missing.
    static const struct gpio_dt_spec _gButton   = GPIO_DT_SPEC_GET_OR(BOOT_BUTTON_NODE, gpios, {0});
    //static struct gpio_callback button_cb_data;
    static void _buttonHandler(struct k_timer *dummy) {
        printk("%" PRId64 "\n", k_uptime_get());
        ltPrintCurrentDatetime();
        int val = gpio_pin_get_dt(&_gButton);
        printk("val=%d, BUTTON_PRESS=%d\n", val, BUTTON_PRESS);
        if (val == BUTTON_PRESS) {
            const power_state_t state = pwrMgmtGetPowerState();
            if (state == POWER_STATE_DOWN) {
                printk("power up\n");
                pwrMgmtPowerUp();
                ledSetG();
            } else {
                printk("power down\n");
                pwrMgmtPowerDown();
    K_TIMER_DEFINE(_gButtonTimer, _buttonHandler, NULL);
    static void _buttonPressed(nrfx_gpiote_pin_t     pin,
                              nrfx_gpiote_trigger_t trigger,
                              void *                p_context) {
    //void button_pressed(const struct device *dev, struct gpio_callback *cb, uint32_t pins) {
        printk("Button pressed at %" PRIu32 "\n", k_cycle_get_32());
        printk("start a timer\n");
        k_timer_start(&_gButtonTimer, K_MSEC(BUTTON_TIMER_MSEC), K_NO_WAIT);
    int buttonInit(void) {
        //int ret;
        nrfx_err_t errCode;
        //ledInit();
        if (!device_is_ready(_gButton.port)) {
            printk("Error: button device %s is not ready\n", _gButton.port->name);
            return ERROR_BUTTON_INITIALIZE_FAIL;
        printk("device_is_ready() ok\n");
    #if 0
        nrfx_gpiote_in_config_t inConfig = NRFX_GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
        inConfig.sense = NRF_GPIOTE_POLARITY_LOTOHI;
        inConfig.pull  = NRF_GPIO_PIN_PULLDOWN; // interrpt: raising edge
        errCode = nrfx_gpiote_in_init(BUTTON_1, &inConfig, button_pressed);
        printk("button state=%d\n", val);
        //if (val == BUTTON_PRESS)
    #else
    	nrfx_gpiote_input_config_t inputConfig = {.pull = NRF_GPIO_PIN_PULLUP};
    	uint8_t gpioteChannel;
    	errCode = nrfx_gpiote_channel_alloc(&gpioteChannel);
    	nrfx_gpiote_trigger_config_t triggerConfig = {
    		.trigger 		= NRFX_GPIOTE_TRIGGER_TOGGLE,
    		.p_in_channel 	= &gpioteChannel
    	nrfx_gpiote_handler_config_t handleConfig = {
    		.handler 	= &_buttonPressed,
    		.p_context 	= NULL
    	errCode = nrfx_gpiote_input_configure(_gButton.pin, &inputConfig, &triggerConfig, &handleConfig);
    	if (errCode != NRFX_SUCCESS) {
    		printk("Error: nrfx_gpiote_input_configure() failed for button, errCode=0x%x\n", errCode);
    	nrfx_gpiote_trigger_enable(_gButton.pin, true);
        return 0;
    What do I need to do to build the example successfully and reproduce the issue at my end?
    I tried building the minimal_log_button_2gpioe project in NCS v2.3.0 but it did not build successfully. Do I need to add something else?
    regards
    Jared
  • Please follow the following procedure to build source code.
    1. Unzip minimal_log_button_2gpioe.zip to ncs/v2.3.0/nrf/samples folder.
    2. Unzip .custom_nrf52832.zip to ncs/v2.3.0/nrf/boards/arm folder.
    3. cd ncs/v2.3.0/nrf/samples
    4. west build -b custom_nrf52832
    I'm able to reproduce the issue, and it seems that setting CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS to more than 1 in the prj.conf should mitigate the issue, even with CONFIG_DEBUG=y.
    I'm not quite sure exactly how but setting CONFIG_DEBUG=y will disable optimization which results in NRFX_ERROR_NO_MEM.
    Have you been able to reproduce it using the normal nRF52832 board not your custom nRF52832 board file?,
    regards
    Jared
