Unable to recover/flash nrf5340 on nrf7002-DK
I recently purchased nrf7002-DK and wanted to evaluate it.
I was first able to flash the blinky example, and it seems to work (although maybe it was the pre-loaded blinky program).
I was hoping to see some output on VCOM1, but I did't see any. I build/flashed the "three thread" example (Board: nrf7002dk_nrf5340_cpuapp_ns). it didn't appear to work (didn't see any LEDs flashing nor message on terminal).
I erased it and tried to re-flash the blinky example, but it would not flash. I have a suspicion that I didn't do the erase process in the correct order.
I used the Programmer v3.0.8, and it shows that "device is protected".
I also tried:
>> nrfjprog --recover --coprocessor CP_NETWORK
Failed to enable coprocessor with unknown error.
ERROR: Access to the selected address is blocked by the SPU.
After doing some search, I cam across the nordic documentation site: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.5.0/nrf/ug_nrf5340.html#readback-protection-error
"Recovering the network core erases the flash memory of both cores. Recovering the application core erases only the flash memory of the application core. Therefore, you must recover the network core first. Otherwise, if you recover the application core first and the network core last, the binary written to the application core is deleted and readback protection is enabled again after a reset."
I probably didn't erase it in the correct order (should have been more careful).
Anyway, is there a way to fix my nrf7002-DK? Have I messed it up beyond repair?
I haven't even got to do any wifi stuff...
Makoto
  • Hi Makoto
    Have you made any changes on the DK itself since you got it? You've connected the micro USB cable to J2 on the DK, correct? And can you make sure that there are indeed jumpers on connectors P22 and P23. You can try writing nrfjprog --recover --family nRF53 --coprocessor CP_APPLICATION to define the family as the error message asks for, but that's not usually necessary.
    You can also add logging to get a .log file with you can upload here so we can take a look at that on our end if the problem persists by adding --log at the end of your command.
    Simon
  • Hi Simon,
    I have not made any changes. Jumpers on P22 and P23 are untouched, and present. I connect my USB cable to J2.
    I tried what you suggested, but with same results:
    nrfjprog --recover --family nRF53 --coprocessor CP_APPLICATION --log
    Recovering device. This operation might take 30s.
    ERROR: Recover failed. Please make sure that the correct device family is given
    ERROR: and try again.
    I got a log.log file out of this command, and will attach here.
    2023-Jun-01 19:16:04  --------------------------------------------------------------------------------
    2023-Jun-01 19:16:04  nrfjprog --recover --family nRF53 --coprocessor CP_APPLICATION --log
    2023-Jun-01 19:16:04  nrfjprog version 10.9.0
    2023-Jun-01 19:16:04  nRF_logger_open
    2023-Jun-01 19:16:04  nRF_logger_open:	nRFJProg logger opened to callback at address 0X1024F3C80
    2023-Jun-01 19:16:04  nRF_open_dll
    2023-Jun-01 19:16:04  nRF_open_dll:	Load library at "/Applications/Nordic Semiconductor/nrfjprog/libjlinkarm_nrf53_nrfjprogdll.dylib".
    2023-Jun-01 19:16:04  . nRF53_logger_open
    2023-Jun-01 19:16:04  . nRF53_logger_open:	nRFJProg logger opened to callback at address 0X10ABDB310
    2023-Jun-01 19:16:04  . nRF53_open
    2023-Jun-01 19:16:04  . . Segger_logger_open
    2023-Jun-01 19:16:04  . . Segger_logger_open:	nRFJProg logger opened to callback at address 0X10ACEB620
    2023-Jun-01 19:16:04  . . Segger_open_dll
    2023-Jun-01 19:16:04  . . Segger_open_dll:	No J-Link DLL path was provided. Attempting to auto detect.
    2023-Jun-01 19:16:04  . . Segger_open_dll:	Load library at "/Applications/SEGGER/JLink/libjlinkarm.7.88.4.dylib".
    2023-Jun-01 19:16:05  . . . Segger_dll_version
    2023-Jun-01 19:16:05  nRF_enum_emu_snr
    2023-Jun-01 19:16:05  . nRF53_enum_emu_snr
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu
    2023-Jun-01 19:16:05  . . Segger_enum_emu_snr
    2023-Jun-01 19:16:05  . . . Segger_enum_emu_snr
    2023-Jun-01 19:16:05  . . . . Segger_get_num_emus
    2023-Jun-01 19:16:05  nRF_connect_to_emu_with_snr
    2023-Jun-01 19:16:05  . nRF53_connect_to_emu_with_snr
    2023-Jun-01 19:16:05  . . Segger_connect_to_emu_with_snr
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_emu
    2023-Jun-01 19:16:05  . . . Segger_connect_to_emu_with_snr
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	Segger logging enabled with callback at 0x4476441664.
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:009.775
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	Firmware: J-Link OB-nRF5340-NordicSemi compiled Nov  7 2022 16:22:01
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:010.185
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:023.296
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	Hardware: V1.00
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:023.392
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	S/N: 1050728904
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:023.479
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	OEM: SEGGER
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:023.550
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:024.333
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	USB speed mode: Full speed (12 MBit/s)
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:025.392
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	TELNET listener socket opened on port 19021
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:025.563
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.092
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	WEBSRV Webserver running on local port 19080
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.173
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 23.720ms returns "O.K."
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.253
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.327
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_Lock()
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.424
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_GetHWStatus(...)
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.641
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.281ms returns 0
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.740
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.821
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.901
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.040ms returns 0x01
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:026.976
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.041
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_ExecCommand("DisableFlashDL", ...).
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.114
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.039ms returns 0x00
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.180
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.243
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.308
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.034ms returns 0x00
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.369
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.433
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_SetHookUnsecureDialog
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.497
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_SetHookUnsecureDialog(...)
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.558
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.154ms returns 0
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.616
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:027.718
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_TIF_Select(JLINKARM_TIF_SWD)
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.217
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.535ms returns 0x00
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.284
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.351
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_SetSpeed(2000)
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.500
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.179ms
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.560
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.622
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_GetSN()
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.680
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.085ms returns 1050728904
    2023-Jun-01 19:16:05  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T28B3280 000:028.738
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 000:028.835
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 000:028.901
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	- 0.032ms returns 0x00
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 000:028.959
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 000:029.022
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	JLINK_ExecCommand("device = Cortex-M33", ...).
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 000:035.908
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	Device "CORTEX-M33" selected.
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 000:036.447
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	- 7.405ms returns 0x00
    2023-Jun-01 19:16:05  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 000:036.532
    2023-Jun-01 19:16:05  . . Segger_read_debug_port_idr
    2023-Jun-01 19:16:05  . . . Segger_read_debug_port_register
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register
    2023-Jun-01 19:16:05  . . . . . Segger_coresight_configure
    2023-Jun-01 19:16:05  . . . . . Segger_coresight_configure:	JLink INFO	T28B3280 000:036.752
    2023-Jun-01 19:16:05  . . . . . Segger_coresight_configure:	JLink INFO	JLINK_CORESIGHT_Configure()
    2023-Jun-01 19:16:05  . . . . . Segger_coresight_configure:	JLink INFO	T28B3280 000:037.231
    2023-Jun-01 19:16:05  . . . . . Segger_coresight_configure:	JLink INFO	- 0.506ms returns 0
    2023-Jun-01 19:16:05  . . . . . Segger_coresight_configure:	JLink INFO	T28B3280 000:037.292
    2023-Jun-01 19:16:05  . . . . . Segger_coresight_configure:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:037.363
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:037.677
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	Value=0x6BA02477
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:037.738
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	- 0.408ms returns 0
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:037.804
    2023-Jun-01 19:16:05  . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . :	JLink INFO	T28B3280 000:037.869
    2023-Jun-01 19:16:05  . . :	JLink INFO	- 0.097ms
    2023-Jun-01 19:16:05  . nRF53_enable_coprocessor
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:038.006
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	JLINK_IsOpen()
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:038.073
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	- 0.105ms returns 0x01
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:038.137
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . :	JLink INFO	T28B3280 000:038.201
    2023-Jun-01 19:16:05  . . :	JLink INFO	JLINK_Lock()
    2023-Jun-01 19:16:05  . . nRF53_enable_coprocessor
    2023-Jun-01 19:16:05  . . :	JLink INFO	T28B3280 000:038.305
    2023-Jun-01 19:16:05  . . :	JLink INFO	- 0.134ms
    2023-Jun-01 19:16:05  . nRF53_select_coprocessor
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:038.435
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:038.498
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	- 0.094ms returns 0x01
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:038.560
    2023-Jun-01 19:16:05  . . :	JLink INFO	T28B3280 000:038.618
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_device
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_device
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 000:038.733
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_device:	JLink INFO	JLINK_IsConnected()
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 000:038.787
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_device:	JLink INFO	- 0.086ms returns FALSE
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 000:038.849
    2023-Jun-01 19:16:05  . . . Segger_is_connected_to_device:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . nRF53_is_coprocessor_enabled
    2023-Jun-01 19:16:05  . . nRF53_select_coprocessor
    2023-Jun-01 19:16:05  . . nRF53_select_coprocessor:	Loading new coprocessor data.
    2023-Jun-01 19:16:05  . . . nRF53_load_coprocessor_data
    2023-Jun-01 19:16:05  . . . . Segger_set_core_data
    2023-Jun-01 19:16:05  . . :	JLink INFO	T28B3280 000:039.069
    2023-Jun-01 19:16:05  . . :	JLink INFO	- 0.251ms
    2023-Jun-01 19:16:05  nRF_recover
    2023-Jun-01 19:16:05  . nRF53_recover
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:039.257
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:039.331
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	- 0.106ms returns 0x01
    2023-Jun-01 19:16:05  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 000:039.395
    2023-Jun-01 19:16:05  . . :	JLink INFO	T28B3280 000:039.498
    2023-Jun-01 19:16:05  . . nRF53_recover
    2023-Jun-01 19:16:05  . . . nRF53_enable_coprocessor
    2023-Jun-01 19:16:05  . . . Segger_write_access_port_register
    2023-Jun-01 19:16:05  . . . . Segger_write_access_port_register
    2023-Jun-01 19:16:05  . . . . . Segger_is_debug_region_powered
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register
    2023-Jun-01 19:16:05  . . . . . . . Segger_write_debug_port_register
    2023-Jun-01 19:16:05  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:039.804
    2023-Jun-01 19:16:05  . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2023-Jun-01 19:16:05  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:040.067
    2023-Jun-01 19:16:05  . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.287ms returns 0
    2023-Jun-01 19:16:05  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:040.120
    2023-Jun-01 19:16:05  . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:040.184
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:040.449
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	Value=0xF0000000
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:040.505
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.349ms returns 0
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 000:040.563
    2023-Jun-01 19:16:05  . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:040.651
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000000)
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:040.956
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.329ms returns 0
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:041.013
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . . . Segger_write_access_port_register:	JLink INFO	T28B3280 000:041.089
    2023-Jun-01 19:16:05  . . . . Segger_write_access_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    2023-Jun-01 19:16:05  . . . . Segger_write_access_port_register:	JLink INFO	T28B3280 000:041.359
    2023-Jun-01 19:16:05  . . . . Segger_write_access_port_register:	JLink INFO	- 0.297ms returns 0
    2023-Jun-01 19:16:05  . . . . Segger_write_access_port_register:	JLink INFO	T28B3280 000:041.415
    2023-Jun-01 19:16:05  . . . . Segger_write_access_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:05  . . . Segger_read_access_port_register
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:547.583
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:548.278
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.829ms returns 0
    2023-Jun-01 19:16:05  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 000:548.530
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 000:548.911
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 000:549.443
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	Value=0x00000001
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 000:549.658
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	- 0.818ms returns 0
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 000:549.804
    2023-Jun-01 19:16:05  . . . . Segger_read_access_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . Segger_read_access_port_register
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register
    2023-Jun-01 19:16:06  . . . . . Segger_write_debug_port_register
    2023-Jun-01 19:16:06  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:056.036
    2023-Jun-01 19:16:06  . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000000)
    2023-Jun-01 19:16:06  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:058.000
    2023-Jun-01 19:16:06  . . . . . Segger_write_debug_port_register:	JLink INFO	- 2.245ms returns 0
    2023-Jun-01 19:16:06  . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:058.455
    2023-Jun-01 19:16:06  . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:058.752
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:059.360
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	Value=0x00000000
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:059.791
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	- 1.169ms returns 0
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:060.049
    2023-Jun-01 19:16:06  . . . . Segger_read_access_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . nRF53_pin_reset
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset
    2023-Jun-01 19:16:06  . . . . . Segger_disconnect_from_device
    2023-Jun-01 19:16:06  . . . . . . Segger_is_connected_to_device
    2023-Jun-01 19:16:06  . . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:060.810
    2023-Jun-01 19:16:06  . . . . . . Segger_is_connected_to_device:	JLink INFO	JLINK_IsConnected()
    2023-Jun-01 19:16:06  . . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:061.041
    2023-Jun-01 19:16:06  . . . . . . Segger_is_connected_to_device:	JLink INFO	- 0.347ms returns FALSE
    2023-Jun-01 19:16:06  . . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:061.273
    2023-Jun-01 19:16:06  . . . . . . Segger_is_connected_to_device:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	T28B3280 001:061.483
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	JLINK_ClrRESET()
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	T28B3280 001:061.907
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	- 0.542ms
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	T28B3280 001:082.736
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	JLINK_SetRESET()
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	T28B3280 001:083.336
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	- 0.771ms
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	T28B3280 001:083.660
    2023-Jun-01 19:16:06  . . . . Segger_pin_reset:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . nRF53_readback_status
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register
    2023-Jun-01 19:16:06  . . . . . . Segger_coresight_configure
    2023-Jun-01 19:16:06  . . . . . . Segger_coresight_configure:	JLink INFO	T28B3280 001:097.313
    2023-Jun-01 19:16:06  . . . . . . Segger_coresight_configure:	JLink INFO	JLINK_CORESIGHT_Configure()
    2023-Jun-01 19:16:06  . . . . . . Segger_coresight_configure:	JLink INFO	T28B3280 001:098.156
    2023-Jun-01 19:16:06  . . . . . . Segger_coresight_configure:	JLink INFO	- 1.017ms returns 0
    2023-Jun-01 19:16:06  . . . . . . Segger_coresight_configure:	JLink INFO	T28B3280 001:098.450
    2023-Jun-01 19:16:06  . . . . . . Segger_coresight_configure:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . . Segger_is_debug_region_powered
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register
    2023-Jun-01 19:16:06  . . . . . . . . Segger_write_debug_port_register
    2023-Jun-01 19:16:06  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:099.147
    2023-Jun-01 19:16:06  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2023-Jun-01 19:16:06  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:099.715
    2023-Jun-01 19:16:06  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.714ms returns 0
    2023-Jun-01 19:16:06  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:100.001
    2023-Jun-01 19:16:06  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:100.237
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:100.596
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	Value=0xF0000000
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:100.769
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.597ms returns 0
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:100.898
    2023-Jun-01 19:16:06  . . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:101.085
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000000)
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:101.417
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.406ms returns 0
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:101.555
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:101.692
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:102.044
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	Value=0x00000003
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:102.184
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	- 0.552ms returns 0
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:102.304
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:102.685
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000010)
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:103.025
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.467ms returns 0
    2023-Jun-01 19:16:06  . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:103.233
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:103.379
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:103.837
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	Value=0x00000001
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:103.986
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	- 0.675ms returns 0
    2023-Jun-01 19:16:06  . . . . . Segger_read_access_port_register:	JLink INFO	T28B3280 001:104.122
    2023-Jun-01 19:16:06  . . . nRF53_readback_status:	Protection status read as NONE
    2023-Jun-01 19:16:06  . . . nRF53_enable_coprocessor
    2023-Jun-01 19:16:06  . . . Segger_halt
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:104.621
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	JLINK_IsConnected()
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:104.765
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	- 0.212ms returns FALSE
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:104.902
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 001:105.128
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 001:105.273
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	- 0.071ms returns 0x00
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 001:105.411
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 001:105.546
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	JLINK_ExecCommand("device = Cortex-M33", ...).
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 001:105.733
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	Device "CORTEX-M33" selected.
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 001:106.264
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	- 0.653ms returns 0x00
    2023-Jun-01 19:16:06  . . . . . Segger_load_core_data:	JLink INFO	T28B3280 001:106.410
    2023-Jun-01 19:16:06  . . . nRF53_is_coprocessor_enabled
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:106.625
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	JLINK_Connect()
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:107.988
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	Found SW-DP with ID 0x6BA02477
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:110.344
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	DPIDR: 0x6BA02477
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:110.492
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	CoreSight SoC-400 or earlier
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:110.610
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	AP map detection skipped. Manually configured AP map found.
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:110.721
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	AP[0]: AHB-AP (IDR: Not set)
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:112.218
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	AP[0]: Skipped. Could not read CPUID register
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:112.372
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	Attach to CPU failed. Executing connect under reset.
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:136.508
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	Failed to power up DAP
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:292.913
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:297.359
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:297.757
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:297.996
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:298.498
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:300.512
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:300.791
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:325.781
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:431.437
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	- 325.272ms returns 0xFFFFFEFB
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	T28B3280 001:432.346
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . Segger_connect_to_device:	JLinkARM.dll reported "-261", "Could not find supported CPU.".
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action:	Attempting to clear any configuration errors in debug port before closing connection.
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action:	JLink INFO	T28B3280 001:433.136
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action:	JLink INFO	T28B3280 001:433.891
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action:	JLink INFO	- 0.946ms returns 0
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action:	JLink INFO	T28B3280 001:434.345
    2023-Jun-01 19:16:06  . . . . . Segger_abort_debug_action:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . nRF53_recover:	Failed to halt the device after recovering.
    2023-Jun-01 19:16:06  . . :	JLink INFO	T28B3280 001:434.549
    2023-Jun-01 19:16:06  . . :	JLink INFO	- 0.267ms
    2023-Jun-01 19:16:06  nRF_close_dll
    2023-Jun-01 19:16:06  . nRF53_close
    2023-Jun-01 19:16:06  . . Segger_is_connected_to_emu
    2023-Jun-01 19:16:06  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 001:435.173
    2023-Jun-01 19:16:06  . . Segger_is_connected_to_emu:	JLink INFO	JLINK_IsOpen()
    2023-Jun-01 19:16:06  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 001:435.300
    2023-Jun-01 19:16:06  . . Segger_is_connected_to_emu:	JLink INFO	- 0.183ms returns 0x01
    2023-Jun-01 19:16:06  . . Segger_is_connected_to_emu:	JLink INFO	T28B3280 001:435.426
    2023-Jun-01 19:16:06  . . Segger_is_connected_to_emu:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . :	JLink INFO	T28B3280 001:435.540
    2023-Jun-01 19:16:06  . . :	JLink INFO	JLINK_Lock()
    2023-Jun-01 19:16:06  . . Segger_close
    2023-Jun-01 19:16:06  . . . Segger_disconnect_from_emu
    2023-Jun-01 19:16:06  . . . . Segger_disconnect_from_emu
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:435.868
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:435.980
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	- 0.167ms returns FALSE
    2023-Jun-01 19:16:06  . . . . . Segger_is_connected_to_device:	JLink INFO	T28B3280 001:436.092
    2023-Jun-01 19:16:06  . . . . . Segger_is_debug_region_powered
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register
    2023-Jun-01 19:16:06  . . . . . . . Segger_write_debug_port_register
    2023-Jun-01 19:16:06  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:436.399
    2023-Jun-01 19:16:06  . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2023-Jun-01 19:16:06  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:436.746
    2023-Jun-01 19:16:06  . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.409ms returns 0
    2023-Jun-01 19:16:06  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T28B3280 001:436.864
    2023-Jun-01 19:16:06  . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:436.978
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:437.291
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	Value=0x00000000
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:437.481
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.565ms returns 0
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	T28B3280 001:437.612
    2023-Jun-01 19:16:06  . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_HasError()
    2023-Jun-01 19:16:06  . . . . Segger_disconnect_from_emu:	JLink INFO	T28B3280 001:437.753
    2023-Jun-01 19:16:06  . . . . Segger_disconnect_from_emu:	JLink INFO	- 0.197ms
    2023-Jun-01 19:16:06  . . . . Segger_disconnect_from_emu:	JLink INFO	T28B3280 001:446.727
    2023-Jun-01 19:16:06  . . . . Segger_disconnect_from_emu:	JLink INFO	JLINK_Close()
    2023-Jun-01 19:16:06  . . Segger_close:	Freeing Library.
    2023-Jun-01 19:16:06  nRF_close_dll:	Freeing Library.
  • Hi Simon,
    I don't know what I did differently, but now I am able to erase via the programmer app.
    I am able to flash the button/blinky program and flash a different button/blinky program.
    as soon as I run: nrfjprog --recover --family nRF53 --coprocessor CP_APPLICATION
    I am not able to flash again, and it gives me the same error. I then use the programmer app to erase it, then I am able to flash from the VS code plugin.
    At lease I am now able to flash it again.
    Thank you for your help!
    Best Regards,
    Makoto
  • Hi
    Glad you got it working at least Makoto. It would be good to resolve what exactly you're seeing though.
    That could be because the NETWORK core is written to and thus protected. If running nrfjprog --recover --family nRF53 --coprocessor CP_APPLICATION results in an error, what does nrfjprog --recover --family --coprocessor CP_NETWORK return?
    Simon
  • Hi Simon,
    After flashing an image, I ran:
    and get:
    then I ran:
    nrfjprog --recover --family nRF53 --coprocessor CP_NETWORK
    and get:
    Then I need to run the Programmer app to erase it in order to be able to flash again.
    Just out of curiosity, I reversed the order of the erase execution. I ran:
    I get:
    then I ran:
    and get:
    I am now able to consistently erase it using the Programmer app, so that is good.
    Not sure why I am not able to erase using the nrfjprog.
    Best Regards,
    Makoto
