Hello Everyone,
Summary
Chip:
nRF52840
OS:
nRF Connect / Zephyr
Problem:
Mobile network connections cause LwM2M (with DTLS) to perform re-registration if the update interval is longer than ~3 minutes.
Details
We're using LwM2M (with DTLS) to monitor / control our nRF52840 uC (connected via an openthread network [OT]).
Working Condition
When the OT boarder router is connected via a fixed connection (within a building) we can set an LwM2M update interval of 5 minutes with no problems. Registration occurs once and updates occur after that point.
Error Condition:
When the OT boarder router is connected via a mobile connection (aka sim) we can't set an LwM2M update interval to more than ~2-3 minutes. If we do set a longer interval for LwM2M all update requests timeout.
This causes the device to perform re-registrations, which has the following effects:
- Increase data usage
- Dropping in and out of the LwM2M server as the connection interval is longer than the expected life time.
Additionally if i disable DTLS encryption then LwM2M may have longer update intervals.
Assumption of the issue
I'm assuming the issue is that the mobile operators network is closing / deleting the NAT entry after 2-3 minutes of no use. Which means the LwM2M server cannot identify the client via the IP+port, forcing the device to re-register / negotiate the DTLS encryption.
From what i've read the following solutions are plausible:
- Replace DTLS encryption in for OSCORE.
- Zephyr doesn't seem to have support for OSCORE yet, there is a module for it but its not in the LwM2M stack at-least.
- Using DTLS 1.2 on the device and server. This allows the connection to be identified by the connection id CID.
- I'm not sure what version of DTLS Zephyr uses.
- Sending empty requests every 2 minutes to keep the port open.
Any help or advise on this issue would be great.
Thanks for your time!
